wiper motor, wanted--wiper motor for 2.0 914 |
rw163014 |
Jun 8 2015, 12:55 PM
Newbie Group: Members Posts: 18 Joined: 6-August 06 From: Bedford In. 47421 Member No.: 6,593 |
I need a wiper motor for 1975 ;914 2.0l
turn signals and horn work ok any advice besides bad motor; does not work at all. (IMG:style_emoticons/default/sad.gif) |
GaroldShaffer |
Jun 8 2015, 01:50 PM
could be a bad switch in the column also. Two things to try.
1) lift the wiper arms off the windshield completely, then turn the wipers on high. Do the arms move at all? If so, then you maybe able to free them up. Take the wipers arms off and all the mounting hardware on the top side of the cowl. Them lube the shafts the best you can. Once done put the big nut back on the shaft and them turn the wipers on high again, while moving lube the shafts again. Turn off wipers and put all the mounting hardware back on, once that is done try the wipers again and see if they wipe while the blades are on the windshield, if they do then you should be good to go. I do this once a year to my 914s to help keep things moving. 2) This is a PITA with the fresh air blower in the way, but if you can see if you can reach the wires to the motor. If you can, check to see if you have voltage to the motor (sorry I don't have the pin outs in front of me) when the wipers are turned on, if you do then I would say your motor is bad, if you don't then sounds like you have a bad switch in your steering column. 3) I have a test working wiper motor if you end up needing one. |
cpfoster |
Jun 8 2015, 02:49 PM
Newbie Group: Members Posts: 9 Joined: 11-May 10 From: Washington, DC Member No.: 11,718 Region Association: None |
Have extra complete wiper assembly with motor if you need one.
euro911 |
Jun 8 2015, 11:44 PM
Checked all your fuses?
rw163014 |
Jun 9 2015, 07:26 AM
could be a bad switch in the column also. Two things to try. 1) lift the wiper arms off the windshield completely, then turn the wipers on high. Do the arms move at all? If so, then you maybe able to free them up. Take the wipers arms off and all the mounting hardware on the top side of the cowl. Them lube the shafts the best you can. Once done put the big nut back on the shaft and them turn the wipers on high again, while moving lube the shafts again. Turn off wipers and put all the mounting hardware back on, once that is done try the wipers again and see if they wipe while the blades are on the windshield, if they do then you should be good to go. I do this once a year to my 914s to help keep things moving. 2) This is a PITA with the fresh air blower in the way, but if you can see if you can reach the wires to the motor. If you can, check to see if you have voltage to the motor (sorry I don't have the pin outs in front of me) when the wipers are turned on, if you do then I would say your motor is bad, if you don't then sounds like you have a bad switch in your steering column. 3) I have a test working wiper motor if you end up needing one. thanks, I will try to check wipers; what would you lubricates them with? if need a motor what would you sell one for sawbones |
rw163014 |
Jun 9 2015, 08:15 AM
DRPHIL914 |
Jun 9 2015, 08:41 AM
phil Edit:: i just reread this a realized you were asking for wiper motor, never mind |
rw163014 |
Jun 10 2015, 05:28 AM
Have extra complete wiper assembly with motor if you need one. What would you want for the whole assemply and what would that include? thanks, sawbones what would price be for motor and assamblyll and do I need the whole assemlbly? thanks |
rw163014 |
Jun 11 2015, 07:39 AM
rw163014 |
Jun 15 2015, 06:08 AM
Have extra complete wiper assembly with motor if you need one. what would you sell the motor for; assume it is functional? thanks sawbones is wiper motor still available. I am not getting any replys to my posts. am I not lookiing iin right place? |
Lo-Fi Version | Time is now: 15th May 2024 - 01:56 PM |
