gas gauge error, reads a couple of gallons low |
JimN73 |
Jun 8 2015, 02:44 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
The gas gauge used to read right, not anymore. When full, the reading is a little over 3/4. The gauge and the reserve light appear to be in sync, reading empty and coming on when there is about 4 gallons left.
I have verified that the resistance in the sending unit is within spec. I have no resistance between the tank connection and the ground. I have cleaned the connections on the tank, the gauge and the fuse. Am I missing something or could there be a problem with the gauge? Thanks |
Mike Bellis |
Jun 8 2015, 02:46 PM
Have you measured voltage and resistance at the gauge? Or did you only test the sender? Bad connections and loos connections and corrosion are other factors in the wiriing.
JimN73 |
Jun 8 2015, 04:32 PM
Mike, I only tested the sender and the wires to the sender and ground - for resistance.
Battery voltage (12 volts+) to the gauge? Where would the resistance check be? thanks. |
Ferg |
Jun 8 2015, 04:38 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Pull the sender on the tank. I've seen corrosion on the wires/rods keep the float from moving up and down freely. There is a pelican article on how to disassemble it to see.
http://www.pelicanparts.com/techarticles/9...der_replace.htm |
Jun 8 2015, 04:51 PM
If the reserve light is coming on with 4+ gallons in the tank (double-check that!!) then your float seems to not be floating so well. Might be time to replace it.
--DD |
forrestkhaag |
Jun 8 2015, 05:34 PM
If the reserve light is coming on with 4+ gallons in the tank (double-check that!!) then your float seems to not be floating so well. Might be time to replace it. --DD or pop it open and carefully clean the trash out of the sender barrel then put it back together and check it out / sound like the same thing mine was doing before I can-opened it and cleaned the sliders and float action. All is well and works perfectly after a few delicate moments of cleaning with a Qtip glued to a clean chopstick and some Acetone to gently clense the wires therein. In any case, it is worth a try before biting the bullet on a new sender. (IMG:style_emoticons/default/beerchug.gif) |
JimN73 |
Jun 8 2015, 05:43 PM
thanks, I see a busy day tomorrow.
toolguy |
Jun 8 2015, 05:56 PM
My daily driver does the same every 4-5 years. . the trouble is caused by deposits from today's crappy gas coating the windings of the sender. . the easy fix is to add Chevron Techrone injection cleaner to a FULL fillup. . May take 2 successive treatments but it works. .
JimN73 |
Jun 8 2015, 06:18 PM
My daily driver does the same every 4-5 years. . the trouble is caused by deposits from today's crappy gas coating the windings of the sender. . the easy fix is to add Chevron Techrone injection cleaner to a FULL fillup. . May take 2 successive treatments but it works. . I'll try this first. |
AlanG |
Jun 8 2015, 06:19 PM
Member Group: Members Posts: 449 Joined: 28-December 12 From: CANADA Member No.: 15,294 Region Association: None |
Pull the sender on the tank. I've seen corrosion on the wires/rods keep the float from moving up and down freely. There is a pelican article on how to disassemble it to see. http://www.pelicanparts.com/techarticles/9...der_replace.htm (IMG:style_emoticons/default/agree.gif) Been there. Done that. Got the t-shirt. |
JimN73 |
Jun 9 2015, 11:13 AM
My daily driver does the same every 4-5 years. . the trouble is caused by deposits from today's crappy gas coating the windings of the sender. . the easy fix is to add Chevron Techrone injection cleaner to a FULL fillup. . May take 2 successive treatments but it works. . One tank of gas, one bottle of techron, one mile of driving - one gauge that works. It's a murracle. thanks, Toolguy |
ripper911 |
Jun 9 2015, 11:45 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Lo-Fi Version | Time is now: 15th May 2024 - 05:42 AM |
