Outer door handles, What's the difference between left and right? |
mr914 |
Jun 9 2015, 06:13 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Putting some more parts on #269. This week, outer door handles.
The door latches have been cleaned with solvent and lightly lubed with lubriplate By themselves, the latches work great. Both catches work and release fine. When I put the outer door handles on, the door won't latch.... Manually moving the prawl back and forth with the door open. After a few times of moving back and forward will result in the prawl catching. I've got the handle with "R" embossed in the passenger door, and L in the driver In looking at the two handles, I can't see any difference. Any thoughts? |
stevegm |
Jun 9 2015, 06:16 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Putting some more parts on #269. This week, outer door handles. The door latches have been cleaned with solvent and lightly lubed with lubriplate By themselves, the latches work great. Both catches work and release fine. When I put the outer door handles on, the door won't latch.... Manually moving the prawl back and forth with the door open. After a few times of moving back and forward will result in the prawl catching. I've got the handle with "R" embossed in the passenger door, and L in the driver In looking at the two handles, I can't see any difference. Any thoughts? IIRC, a slight difference in the curvature of the flap. But, you've got it correct - R is passenger, L is drivers side. |
era vulgaris |
Jun 9 2015, 06:55 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
The handles follow the curve of the door. If they're on the wrong side you can tell if you're looking for it. At a passing glance though it's a small enough deviation that it might not be noticed.
mr914 |
Jun 9 2015, 08:06 PM
So, left to right swapping is not the problem.
Any suggestion on why the door won't latch when the outer handle is bolted on the right door? |
rgalla9146 |
Jun 9 2015, 08:37 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
You've had both of the door latch mechanisms out of the doors, cleaned them and lubed them ? operated them in your hands and they work smoothly on both catches ?
does the lock feature slide up and down easily with a positive stop, up and down ? and in and out ? If not, start over. Is it possible that when you mount the handle that it is pushing in on the release arm ? When it is mounted can you lock and unlock with the key ? |
Hank914 |
Jun 9 2015, 08:46 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
You've had both of the door latch mechanisms out of the doors, cleaned them and lubed them ? operated them in your hands and they work smoothly on both catches ? does the lock feature slide up and down easily with a positive stop, up and down ? and in and out ? If not, start over. Is it possible that when you mount the handle that it is pushing in on the release arm ? When it is mounted can you lock and unlock with the key ? (IMG:style_emoticons/default/popcorn[1].gif) I'm also interested in this topic. My outside handle on the drivers door started sticking (stayed in the open position) last week, now this week doesn't open. Opens fine from inside of driver's door. Sounds like I just need to remove, clean it, lube and replace? |
mr914 |
Jun 9 2015, 09:06 PM
You've had both of the door latch mechanisms out of the doors, cleaned them and lubed them ? operated them in your hands and they work smoothly on both catches ? does the lock feature slide up and down easily with a positive stop, up and down ? and in and out ? If not, start over. Is it possible that when you mount the handle that it is pushing in on the release arm ? When it is mounted can you lock and unlock with the key ? Yes, removed, cleaned, lubed and installed. Works fine without outer handle. Keys work fine. Even re-keyed the lock sets so one key works for all locks. Is it possible that when you mount the handle that it is pushing in on the release arm ? OK, how can that happen? The nylon pusher is the same on both sides and the two gaskets are in place. Will give switching handles from one side to another a shot. |
McMark |
Jun 10 2015, 09:17 AM
QUOTE Is it possible that when you mount the handle that it is pushing in on the release arm ? Bent internal release mechanism.OK, how can that happen? The nylon pusher is the same on both sides and the two gaskets are in place. |
Rob-O |
Jun 10 2015, 06:06 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
QUOTE Is it possible that when you mount the handle that it is pushing in on the release arm ? Bent internal release mechanism.OK, how can that happen? The nylon pusher is the same on both sides and the two gaskets are in place. Yup, what Mark said. Probably mashed on when the mechanism was all gummed up and now is slightly bent. |
URY914 |
Jun 10 2015, 06:53 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,563 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Lo-Fi Version | Time is now: 14th May 2024 - 09:14 AM |
