| jhadler |
Jun 11 2015, 01:37 PM
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Hi all,
Just a quick hypothetical... If I managed to get a hold of 2.5L subie motor from an automatic, would that motor work with a manual subie gear box? -Josh |
| Nine_14 |
Jun 11 2015, 01:55 PM
Member ![]() ![]() Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany |
| ahycaramba |
Jun 11 2015, 01:57 PM
“I live my life a quarter mile at a time.” ![]() ![]() Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California
Hi Josh,
There should be no problems swapping automatic for manual trans. The only thing (not sure) you might need a difference engine ecu for manual trans especially if the engine and trans ecu is one complete unit. There are after market ecu's out there that will work with a plus side to it too. After market like "Stinger", can be dialed in for your car specifications and needs. Good luck Al |
| Dave_Darling |
Jun 11 2015, 06:21 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,298 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
And, of course, you'd need new head gaskets every few years... (IMG:style_emoticons/default/rolleyes.gif)
--DD |
| DBCooper |
Jun 11 2015, 06:55 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Nah, no more often than T4 motors drop exhaust valves.
| 76-914 |
Jun 11 2015, 07:07 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,823 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
You can use the OEM ECU. You'll need to ground 1-2 wires to raise the idle speed. You will need to wire 2 of the 4 wire's coming off the VSS sender on the tranny back to the ECU.
| jhadler |
Jun 15 2015, 02:03 PM
And, of course, you'd need new head gaskets every few years... (IMG:style_emoticons/default/rolleyes.gif) --DD Well, the reason I ask is that it's possible my daily driver Subaru may be totaled from hail damage, and I JUST shelled out a bunch of money on a head gasket job less than two months ago... Maybe take the total if I can get a replacement, then I've got a scooby motor for the teener??? -Josh |
| JRust |
Jun 15 2015, 03:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Well, the reason I ask is that it's possible my daily driver Subaru may be totaled from hail damage, and I JUST shelled out a bunch of money on a head gasket job less than two months ago... Maybe take the total if I can get a replacement, then I've got a scooby motor for the teener??? -Josh Sounds like a good plan. If you were going to use the 901 I have the conversion stuff for that in the classifieds. I would go for the suby tranny though if choosing between the 2. The 901 will certainly work & is a good cheap temporary solution. Once you drove one with a suby trans you wouldn't want o go back though (IMG:style_emoticons/default/evilgrin.gif) |
| 76-914 |
Jun 15 2015, 06:05 PM
(IMG:style_emoticons/default/agree.gif) If you gut your Suby don't get in a hurry to get rid of the carcass. There are many items besides the engine that you'll want to use later.
Lo-Fi Version | Time is now: 7th December 2025 - 04:24 AM |
