Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
EdwardBlume |
Jun 16 2015, 06:42 PM
So black is your always on power right? What is always on in the front trunk? Plus, if the fuel pump in the front trunk was not connected to anything could this be my arc without ignition?
Mike Bellis |
Jun 16 2015, 08:32 PM
So black is your always on power right? What is always on in the front trunk? Plus, if the fuel pump in the front trunk was not connected to anything could this be my arc without ignition? If your fuel pump was not connected and the wire were not touching anything, that is not the cause of your spark. Red is constant power at the headlight relay. Not black. Black from your ignition switch is "hot while cranking". When's the build party? (IMG:style_emoticons/default/chair.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:55 PM |
