Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
Dave_Darling |
Jun 17 2015, 11:58 AM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There are, sadly, some unfused circuits. Even on cars with unmodified wiring. I don't remember what they are offhand, but digging through the wiring diagrams will show them. Look for lines coming straight from the battery that don't go through any "Sx" (where x is a number) before getting to some component.
--DD |
Kansas 914 |
Jun 17 2015, 01:07 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
There are, sadly, some unfused circuits. Even on cars with unmodified wiring. I don't remember what they are offhand, but digging through the wiring diagrams will show them. Look for lines coming straight from the battery that don't go through any "Sx" (where x is a number) before getting to some component. --DD DD - I didn't know that about unfused circuits - or if it was mentioned before I chose to forget it as it is scary. We should document that here for future reference. That is important to know. Thanks! |
Lo-Fi Version | Time is now: 19th May 2024 - 03:52 PM |
