Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
Mike Bellis |
Aug 9 2015, 04:30 PM
I found lots of little things with Rob's car but nothing major. I guess the biggest issue if you call it that was the fuel cut off relay was connected to constant power and not switched, so it would always cut off fuel. Up/Down on one headlight flipped. Park turn wires on front left turn signal was flipped. Brake light switch arm not hitting brake pedal assembly correctly. Lots of corrosion in lamp sockets. Had to run fuel level signal to center console. connect center console gauges. connect and wire radio and speakers. install LED front lamp boards. The biggest this messing with me (and him) at the beginning was the loose ground at the battery. I would have power and them no power. Once we got it tight, it was easy to track down the issues.
Things to do: Reconnect starter (yellow) wire at started. It's removed for testing. Tighten all oil lines and fittings, fill with oil! Reinstall interior pieces. (some we removed today) Bleed brakes. Tie up loose wire and cables. Charge battery. The PO did a pretty good job on the wiring even though I fixed some of his work. The car is super clean! Every part is new or restored. This is the first time I spent real time in/on this car and I want it! Just beautiful... (IMG:style_emoticons/default/wub.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:38 AM |
