Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
Mike Bellis |
Aug 14 2015, 07:22 PM
Actually the high beams are the only lights working. That is why the fogs do not work. They have to be off to trigger the fog relay. You need a new hi/lo relay. I have a Saab relay we can make work by adding a jumper to one of the pins.
For those that care... If you remove the white/blue wire from the high beam fuse and ground it, the fogs will work on high or low lights. If you also take the power lead (from the headlight switch) and give it power, the fogs will work any time. For Rob... That is the smaller white wire with a dark stripe. I think it's connected to fuse 2. |
EdwardBlume |
Aug 16 2015, 05:43 PM
Actually the high beams are the only lights working. That is why the fogs do not work. They have to be off to trigger the fog relay. You need a new hi/lo relay. I have a Saab relay we can make work by adding a jumper to one of the pins. For those that care... If you remove the white/blue wire from the high beam fuse and ground it, the fogs will work on high or low lights. If you also take the power lead (from the headlight switch) and give it power, the fogs will work any time. For Rob... That is the smaller white wire with a dark stripe. I think it's connected to fuse 2. Thanks Mike. I replaced the wiper switch but the 74 turn signal switch didn't line up. I think I must have a 75 switch on the late 74. My hi lo switch doesn't exist and nothing catches when pulling the lever back... i think it's time to put the interior back in, then check the oil lines. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:01 PM |
