Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jul 23 2015, 08:38 PM
Is this connection missing a pin? It's under the steering looks like an indicator connection. Black and red wire.
Attached thumbnail(s) |
JeffBowlsby |
Jul 23 2015, 09:39 PM
914 Wiring Harnesses Group: Members Posts: 8,486 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Check to see if you have 5 wires to that connector, that cavity should have a brown/black wire. Its your intermittent wiper delay circuit. I bet its there. What seems to be missing is the male prong from the wiper switch...you must have some other switch in there that does not have the wiper delay circuit in it.
EdwardBlume |
Jul 23 2015, 10:15 PM
Yep, 5 wires in, 4 prongs connecting. You can see the wire (blurry)... brown and black? Dang.
EdwardBlume |
Jul 24 2015, 11:13 PM
Put a new ignition switch in, the old one looked OK though. Did find 2 unattached wires though coming from the ignition switch. That's not right is it?
EdwardBlume |
Jul 29 2015, 12:12 AM
I think I'm getting closer to the issue. With battery on, the headlights are live. Headlight switch off, still live.
Ignition switch which should be live is completely without power. In fact, there's two wires just dangling there. Best I can figure, one is where the real live should go, the other should be switched back to the lights or seats or something. JWest fuse box looks good. Headlight switch is out but there's a ton of wires to it. What do you think? Pict one are the two stray wires off the ignition switch. One for sure is power. Attached thumbnail(s) |
EdwardBlume |
Jul 29 2015, 12:15 AM
Next pict is the fuse box. Does this look right to you?
EdwardBlume |
Jul 29 2015, 12:18 AM
Last pict set is the headlight switch. Looks like power shares a connection with a slightly different wire....
EdwardBlume |
Jul 29 2015, 12:22 AM
Darn... crappy picts... need to study the headlight switch now.... (IMG:style_emoticons/default/type.gif)
76-914 |
Jul 29 2015, 09:00 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/poke.gif) Even Andy takes better pic's than that. (IMG:style_emoticons/default/wacko.gif) In the 1st pic; is that a burn spot on the red wire adjacent to the insulation covering the spade? Also, notice the witness marks on that same sheathing. It appears that those indentations are the result of two opposing spade connections pressing against it. Like this l=
McMark |
Jul 29 2015, 09:55 AM
The two wires in your hand are for the cigarette lighter.
Can't do much with the blurry pics. If you're using a cell phone, get a camera. If you're using a camera, set it to Macro mode. Or take the pictures from farther back. Good light on the subject can reduce blur as well so get out the shoplights. |
EdwardBlume |
Jul 29 2015, 10:32 PM
The two wires in your hand are for the cigarette lighter. Can't do much with the blurry pics. If you're using a cell phone, get a camera. If you're using a camera, set it to Macro mode. Or take the pictures from farther back. Good light on the subject can reduce blur as well so get out the shoplights. You're right. I got deeper in and saw the bigger starter wire in there (yellow) and the larger live wire (orange?). The PO deleted the cigarette lighter and the fasten seat belt light. Wires are still there though. |
EdwardBlume |
Jul 29 2015, 10:33 PM
I made some progress though .....
EdwardBlume |
Jul 29 2015, 10:39 PM
I adjusted the headlights so they are down at lights off. The relays or motors still click when you connect the battery.
Pulling the light switch on to park, the 4 corners lit up, but pulling the headlights on doesn't lift the lights or light the H4s. Pulling the hazard switch lit up the dash but no flashing. Turn signal does not work. Progress. Attached thumbnail(s) |
Mike Bellis |
Aug 9 2015, 04:30 PM
I found lots of little things with Rob's car but nothing major. I guess the biggest issue if you call it that was the fuel cut off relay was connected to constant power and not switched, so it would always cut off fuel. Up/Down on one headlight flipped. Park turn wires on front left turn signal was flipped. Brake light switch arm not hitting brake pedal assembly correctly. Lots of corrosion in lamp sockets. Had to run fuel level signal to center console. connect center console gauges. connect and wire radio and speakers. install LED front lamp boards. The biggest this messing with me (and him) at the beginning was the loose ground at the battery. I would have power and them no power. Once we got it tight, it was easy to track down the issues.
Things to do: Reconnect starter (yellow) wire at started. It's removed for testing. Tighten all oil lines and fittings, fill with oil! Reinstall interior pieces. (some we removed today) Bleed brakes. Tie up loose wire and cables. Charge battery. The PO did a pretty good job on the wiring even though I fixed some of his work. The car is super clean! Every part is new or restored. This is the first time I spent real time in/on this car and I want it! Just beautiful... (IMG:style_emoticons/default/wub.gif) |
kconway |
Aug 10 2015, 01:45 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Wow, sorry guys. I knew it needed some sorting but had no idea I goofed up so many of the connections. Glad you made some progress.
Kevin |
Mike Bellis |
Aug 10 2015, 04:52 PM
Wow, sorry guys. I knew it needed some sorting but had no idea I goofed up so many of the connections. Glad you made some progress. Kevin Kevin, this car is amazing! These sort of issues are pretty normal when reassembling a car. Poor Rob has color blindness which compounds the troubleshooting issue. I will be back in a couple weeks to help finish sorting out the last few items and get this thing running. I really love this car. It reminds me of my first 914. It's almost like a new car with all the parts being new or restored. Rob really wants to sell it to me... (IMG:style_emoticons/default/poke.gif) |
EdwardBlume |
Aug 11 2015, 10:11 PM
Big thanks to Mike Bellis... (IMG:style_emoticons/default/aktion035.gif)
There's a few more things on the list, but definitely close. Additional items: 1) Fog lights don't power - switch is lit, power OK to S1, fuse OK, yellow wires are connected between lights, but no juice. Either the switch or the relay. 2) No horn 3) No high beam - may need to replace both column levers 4) Replace stub pipes 5) Alignment 6) Front valence... |
EdwardBlume |
Aug 11 2015, 10:12 PM
Aug 11 2015, 10:57 PM
For the fog lights, turn them on and check for power at the fuse, and after the fuse, and on the wire, and at the socket. Remember that the stock circuit requires the headlights to be on in order to send power to the fog lights.
For the horn, there is a separate relay on top of the fuse panel for the horn. When the brown/white wire going up the steering column is grounded, the relay gets triggered, and sends power to the horn. So check that the correct pin (85 or 86?) on the relay gets grounded when you press the horn button, and that the relay has power on the other of those two pins and 30 as well, when the key is on. And so on. --DD |
EdwardBlume |
Aug 14 2015, 06:36 AM
For the fog lights, turn them on and check for power at the fuse, and after the fuse, and on the wire, and at the socket. Remember that the stock circuit requires the headlights to be on in order to send power to the fog lights. For the horn, there is a separate relay on top of the fuse panel for the horn. When the brown/white wire going up the steering column is grounded, the relay gets triggered, and sends power to the horn. So check that the correct pin (85 or 86?) on the relay gets grounded when you press the horn button, and that the relay has power on the other of those two pins and 30 as well, when the key is on. And so on. --DD I have power at the fuse, but no power to the lights. The high beam isn't working so I think that's it. Might just ground the blue/white wire to check. Horn is now working! The dino wheel adapter wasn't making contact so I cleaned the grease off the inside ring, bent the inner flaps out, and honk! (IMG:style_emoticons/default/cheer.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:00 AM |
