Electric Avenue is Bright, Finishing the ABM Electrics |
Mike Bellis |
Aug 14 2015, 07:22 PM
Actually the high beams are the only lights working. That is why the fogs do not work. They have to be off to trigger the fog relay. You need a new hi/lo relay. I have a Saab relay we can make work by adding a jumper to one of the pins.
For those that care... If you remove the white/blue wire from the high beam fuse and ground it, the fogs will work on high or low lights. If you also take the power lead (from the headlight switch) and give it power, the fogs will work any time. For Rob... That is the smaller white wire with a dark stripe. I think it's connected to fuse 2. |
EdwardBlume |
Aug 16 2015, 05:43 PM
Actually the high beams are the only lights working. That is why the fogs do not work. They have to be off to trigger the fog relay. You need a new hi/lo relay. I have a Saab relay we can make work by adding a jumper to one of the pins. For those that care... If you remove the white/blue wire from the high beam fuse and ground it, the fogs will work on high or low lights. If you also take the power lead (from the headlight switch) and give it power, the fogs will work any time. For Rob... That is the smaller white wire with a dark stripe. I think it's connected to fuse 2. Thanks Mike. I replaced the wiper switch but the 74 turn signal switch didn't line up. I think I must have a 75 switch on the late 74. My hi lo switch doesn't exist and nothing catches when pulling the lever back... i think it's time to put the interior back in, then check the oil lines. |
EdwardBlume |
Aug 16 2015, 05:45 PM
Oh and thanks...
Attached thumbnail(s) |
Mike Bellis |
Aug 16 2015, 07:32 PM
When I was there, I could hear the relay click. This means there is nothing wrong with the switch. You only need the relay.
Oh, you're welcome. |
EdwardBlume |
Aug 17 2015, 06:45 PM
Does the Saab relay take care of the H4s or are additional wiring needed?
Mike Bellis |
Aug 17 2015, 08:26 PM
Does the Saab relay take care of the H4s or are additional wiring needed? The Saab relay has extra external pins that are joined in the 914 relay. The Saab is also electronic switching and does not rely on the old coil/cam system like the 914. It's also twice as wide but will tuck up nicely under the dash. Here is my thread on this mod for your reading pleasure... http://www.914world.com/bbs2/index.php?sho...lectronic+relay |
EdwardBlume |
Aug 18 2015, 01:51 PM
I tested the interior light and got 6 volts. Too low to light the lamp.
Lo-Fi Version | Time is now: 2nd May 2024 - 06:31 PM |
