lonewolfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California ![]() |
What kind of piston rings are you running on your JE Racing 96.0 stroker pistons? I'm building a 2258cc. It looks like most of the kits use Hastings rings. EMW has NPR they sell. Has anyone used Deves or Total Seal rings? Do you have feedback on what you've used?
colingreene |
Senior Member ![]() ![]() ![]() Group: Members Posts: 742 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California ![]() |
The rings i got from NPR have been fine. use those.
Total seal are finicky Why do you need forged pistons though? |
lonewolfe |
The rings i got from NPR have been fine. use those. Total seal are finicky Why do you need forged pistons though? Thanks for the reply Colin! I bought a bunch of parts from a guy who was going to build a 2258cc motor but ended up selling the car before using these parts. I got a great deal on this stuff. It included a 78.0mm crank w/ VW Type 1 journals and the JE Racing pistons. All this stuff was new. There were no rings with the pistons though. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
All JE pistons have a laser engraved number on the bottom side. I can order the correct ones through Pelican. Give ne a call at 888 280 7799 ext 330 if you need help.
Bruce |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
2258 is going to be killer fun.....give it good breathing & you'll love it!
jeff |
Member ![]() ![]() Group: Members Posts: 255 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 ![]() |
Give these guys a call...http://lnengineering.com/resources/category/watercooled-engines-parts-and-upgrades/
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Give these guys a call...http://lnengineering.com/resources/category/watercooled-engines-parts-and-upgrades/ (IMG:style_emoticons/default/agree.gif) Charles has a large contract with JE, likely the JE rings are NPR as they are made in Japan, but it's to JE's spec. To me total seal is a gimmick and I had issues with a set, I have used Deves on a /6 with good results but that was many moons ago. |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
colingreene |
I have a 2258, its alright.
lonewolfe |
lonewolfe |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
The parent company of JE owns Nippon ring company.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,012 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I've used total seal and deves on old race 2.0/4 in the 90's but for street I would buy from JE
Jake Raby |
You have to watch fitting rings to JE pistons. You may find a Grant or other ring thats the proper width and tension, but the radial depth will be completely wrong.
That one will only bite you once, but it may take you eons to find where you went wrong. |
lonewolfe |
You have to watch fitting rings to JE pistons. You may find a Grant or other ring thats the proper width and tension, but the radial depth will be completely wrong. That one will only bite you once, but it may take you eons to find where you went wrong. Thanks Jake! It sounds like the NPR rings are the way to go with these Pistons! |
colingreene |
i just have a really eccentric view of enough power.
And it likes to turn the oil pressure light on. I also had some weird carb tuning issues i need to sort out but without a wideband im pissing up a rope, so i have one on the way and will figure it out soon enough. |
lonewolfe |
i just have a really eccentric view of enough power. And it likes to turn the oil pressure light on. I also had some weird carb tuning issues i need to sort out but without a wideband im pissing up a rope, so i have one on the way and will figure it out soon enough. Once you get your carbs properly setup you'll be a much happier camper. The A/F ration gauge will really help you get them dialed in. Before you start adjusting your carbs for A/F you need to make sure they are syncroized. Do you have a carb sync tool? If not you need to get one. This is the type to get, Snail Type Syncrometer Carb Sync Tool, GERMAN, SK Model. You can find these from many online VW/Porsche parts retailers. Here's a link for one of them: http://vwparts.aircooled.net/Snail-Type-Sy...SK-p/ste-sk.htm |
Lo-Fi Version | Time is now: 14th July 2025 - 08:22 PM |
