I need a quick how 2 pull rotors |
spare time toys |
Feb 23 2005, 05:59 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Is there any trick to pull the rear rotors or do they just slip over the studs? The fronts are easy just wondered about the rears. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Mueller |
Feb 23 2005, 06:02 PM
remove wheel, remove caliper, remove rusted or stripped flat head screw........rotor should slide right off (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
914werke |
Feb 23 2005, 06:05 PM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Studs? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
As mike said then hit um with a BFH (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Aaron Cox |
Feb 23 2005, 06:07 PM
those 2 screws are a PITA.... old school impact driver (hit with a hammer and use a large slotted tip bit)
seanery |
Feb 23 2005, 06:19 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
yup, I needed the impact driver on the 72.
Sears has em for about $15. Soak it with PB Blaster then wack away. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Spoke |
Feb 23 2005, 08:01 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Mine were rusted pretty good. Pounded one off, the other I used the threaded hole next to the stupid holding screw to put a bolt into and it pushed it right off, no pounding necessary.
Spoke |
Eric_Shea |
Feb 24 2005, 09:49 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) with all those other weirdos...
1. Impact Driver - Please do this. Buy one. I get 1/2 my hubs with those screws broken off and it's a pain to drill and retap them. Use the impact driver and a MAP torch (get them red hot) and those screws will twist right out. 2. As just mentioned, there's a couple of other threaded holes in the rotor. take any 8x1.25 bolt (your average 10mm) that you have laying around and screw it in one or both of those holes. Those are there to literally press the rotor off the hub. Easy as 1,2 |
Lo-Fi Version | Time is now: 16th May 2024 - 06:17 PM |
