| LukeD |
Jun 16 2015, 02:35 PM
Member ![]() ![]() Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
I consider myself somewhat intelligent but I can't seem to wrap my head around this entirely. I've searched and searched but seems the existing information is lacking, I even called Pelican and the guy I spoke with couldn't help me with what rubber lines to order. I found this article from a search but it doesnt address the SS lines http://www.pelicanparts.com/914/technical_...4_20FI_diag.htm
I am replacing the tunnel and engine compartment plastic lines with the Pelican Stainless ones. The tunnel lines are 8mm and 9.5mm Outside Diameter (OD) From what I can tell the fuel lines to the injectors are supposed to be 7mm inside diameter (ID) so I assume the SS engine compartment lines are 8mm OD? (specs on these are not listed on Pelican site, only the tunnel lines) At the fuel pump/filter how to I go from 7mm ID to 9.5mm OD? Trying to determine what size rubber lines and approximate lengths to get the job done. |
| JawjaPorsche |
Jun 16 2015, 02:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Call Chris at Tangerine Racing. He will take time to answer all your questions.
http://tangerineracing.com/contact_us.htm |
| LukeD |
Jun 16 2015, 03:16 PM
Call Chris at Tangerine Racing. He will take time to answer all your questions. http://tangerineracing.com/contact_us.htm Thanks! I just called and spoke with him |
Lo-Fi Version | Time is now: 4th October 2026 - 12:48 PM |
