I consider myself somewhat intelligent but I can't seem to wrap my head around this entirely. I've searched and searched but seems the existing information is lacking, I even called Pelican and the guy I spoke with couldn't help me with what rubber lines to order. I found this article from a search but it doesnt address the SS lines http://www.pelicanparts.com/914/technical_...4_20FI_diag.htm
I am replacing the tunnel and engine compartment plastic lines with the Pelican Stainless ones. The tunnel lines are 8mm and 9.5mm Outside Diameter (OD)
From what I can tell the fuel lines to the injectors are supposed to be 7mm inside diameter (ID) so I assume the SS engine compartment lines are 8mm OD? (specs on these are not listed on Pelican site, only the tunnel lines)
At the fuel pump/filter how to I go from 7mm ID to 9.5mm OD?
Trying to determine what size rubber lines and approximate lengths to get the job done.
