Cool vid! GT3 RS at Sebring |
Jeroen |
Feb 23 2005, 07:06 PM
This guys is flying
Very nice footwork too (hee/toe double clutch downshifts) If a 914 could only shift like that (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Nice whine from the gearbox too http://gscdownloads.com/leh/sebring/GT3RSatSebring.wmv |
Tom Perso |
Feb 23 2005, 07:46 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Holy crap, that's pretty damned impressive!
I like the part where he downshifts (double clutched and heel-toe) from 6th all the way to 1st. Classic. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Later, Tom |
TimT |
Feb 23 2005, 07:51 PM
leh keen..Kingleh
young guy lot of talent, and lots of money.. ... is this really "club racing" anymore? Ill shut up now.. btw yea he can drive |
jr91472 |
Feb 23 2005, 07:54 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Stutgart46 |
Feb 23 2005, 08:06 PM
Stutgart46 Group: Members Posts: 396 Joined: 20-November 03 From: Houston, TX Member No.: 1,365 |
Sweet. I have done a 2:29 there and I felt like I was flying.
Thanks for the video. |
URY914 |
Feb 23 2005, 08:23 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,273 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
If you play it at half speed, it will be just like when I use to race there. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Paul |
Aaron Cox |
Feb 23 2005, 08:28 PM
6th to first was impressive.....
prety cool...bumpy track |
URY914 |
Feb 23 2005, 08:31 PM
And flat as an old airport. Oh, it was an old airport...that's right. |
double-a |
Feb 23 2005, 08:33 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
******* noob alert *******
what is double-clutching and heel-toeing? ~a |
TimT |
Feb 23 2005, 08:39 PM
You wont learn double clutch or heel toe watching this vid
ppickerell |
Feb 23 2005, 08:42 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
You have to watch it 3 times to fully appreciate. Once for the track view, once for the feet, and once for the hands.
JohnM |
Feb 23 2005, 10:16 PM
914 enduro driver Group: Members Posts: 179 Joined: 23-July 04 From: San Diego Member No.: 2,387 |
Enjoyed watching that. Look at his head bobbing around in the rear view. I would have liked to seen a PIP with tach and speedo in top right corner of this clip. Probably stringing redline downshifts. No doubt his time would have been better without the traffic and being able to take the optimal line a couple of times. This guy is one with his machine.
double-a |
Feb 23 2005, 10:23 PM
don wanna learn it, just like to know what the heck it is. ~a |
MattR |
Feb 23 2005, 10:30 PM
Nice video! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Andyrew |
Feb 23 2005, 10:55 PM
Looks like he was skatin on those tires the whole time...
airsix |
Feb 24 2005, 12:42 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
A technique of using your right foot to control both the throttle and brake at the same time. This allows you to match the engine rpm with the speed of the transmission input shaft as you engage the clutch durring a downshift while braking. If you do it correctly It makes braking and downshifting at the same time a smooth opperation that does not upset the car and allows you to brake hard while at the same time always being in the correct gear for whatever speed you are traveling. Technically you are using the ball of your foot on the brake pedal and your little toes on the gas pedal. It takes some practice and proper pedal height/spacing to make it work well. The pedal arrangement in a 914 makes it fairly easy. The technique is called "heel and toe" because very early cars had brakes actuated by your heel and throttle actuated by your toes. The name just stuck even though it doesn't make sense any more. A quick way to learn the technique is to set your idle so low that the engine will stall unless you keep a foot on the gas. You'll quickly learn to brake and feather the throttle at the same time to keep the engine running. You'll be heel-n-toe downshifting in no time. -Ben M. |
scotty914 |
Feb 24 2005, 12:56 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
as for somebody say if a 914 could shift like that, i dont think the shifting had anything to do with it a 914 does not even have a throttle response good enough if the car should shift that well.
and for the nood question, double clutching is letting the clutch out during shifts when the car is in nuetral to use the engine to match gear rpms, but to do this well you need to be able to heel toe it which is using your foot to hit the brakes and gas at the same time, in a very controlled manor to bring the rpms up the the point where the gears are moving at the same speed. this has very little wear on syncros and helps prevent spins when the rear wheels suddenly try to turn at a faster or slower speed as well as slowing the car with the brakes |
Andyrew |
Feb 24 2005, 01:00 AM
I feather the throttle all the time.. and heel and toe durring downshifts..
Its common practice for me now.. Im starting to practice left foot breaking (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Now, Double clutching is just doing two clutch actions, one to disengage the gear, and one to engage it... Am I correct or... I never got the double clutch one.... (tried doing two actions once really fast, just felt slow.. and my left leg hurt from moving so fast... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) ) |
scotty914 |
Feb 24 2005, 01:07 AM
you dont need to totally disengage the clutch, just enough to get the gear to slacken up to go in to nuetral, then once the gear speeds are the same the second slack allows the gear to engage, done right you can stop the car from spinning, save wear on the tranny and is faster track times |
Lou W |
Feb 24 2005, 01:27 AM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Lo-Fi Version | Time is now: 30th April 2024 - 01:43 AM |
