3 Pages V  1 2 3 >
> Looking at buying a 914-6 - Opinions needed ASAP!
Cuda911
post Jun 18 2015, 10:03 PM
I have an offer in on the car. Need your opinions quick, stat, pronto!
Decided to start a new clean thread, since I was piggy-backing onto someone else's thread.
The original thread is here:
http://www.914world.com/bbs2/index.php?sho...=258093&hl=
Took the car for a good drive.
Engine fired right up, sounded very good.
Shifting was about as sloppy as one can imagine. If I hadn't driven 914s before, this car would have been nearly undriveable.
More rust than I had hoped for. There was no way to take the rockers off, so any purchase would be contingent on a more thorough inspection. I felt up under them... seemed greasy, but not rusty.
The car will need some significant restoration. Paint code is 80 (Ivory) and I have a personal "no black car" policy, so at least going back to stock color will be good for me.
Certificate of Authenticity has been ordered. Believed to be a numbers matching car.
Some items/issues:
- The ever-popular broom-stick mod for rear trunk.
- Rear trunk latch broken
- Front trunk won't open, cable broken. Needs to be fixed before can fill it with gas (the cable recently broke... guesstimate it is down to 1/4 tank).
- Fuel gauge broken.
- Glove box missing (the door is there, but hanging loose, no box behind it).
- Some rips in seat vinyl.
- Cracked dash, loose dash vinyl .
- Passenger door pocket is loose.
- oil leak.
- Terrible paint.
- Chrome on bumper is terrible.
- Rust: see pix, they should be pretty self-explanatory.
- What are those round areas in the rear trunk that are sealed over? My 914-4's have similar ones, but that larger one on this car doesn't seem original to the manufacture of the car.
- Shocks are shot.
- Shifter is a total mix-master. Could beat eggs to a froth with all that slop.
Plus items:
It's a six.
Cool license plate.
Local car.
Pix to follow in a moment:
Cuda911
post Jun 18 2015, 10:06 PM
Pix: (will post in a few batches):
Cuda911
post Jun 18 2015, 10:08 PM
Batch 2:
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Mikey914
post Jun 18 2015, 10:09 PM
The rubber man
If it's not to crazy on the money DO IT you know you want to. Hell, it'll probably do better than your 401K they way these are going.
Cuda911
post Jun 18 2015, 10:14 PM
Batch 3:
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Cuda911
post Jun 18 2015, 10:19 PM
Batch 4:
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Cuda911
post Jun 18 2015, 10:22 PM
Last batch:
Tom_T
post Jun 18 2015, 10:29 PM
TMI....
Mike,
Check if the engine & trans numbers are matching - if it doesn't have a COA to confirm - then PCNA may confirm it for you on the phone if you give them the numbers verbally or in emailed pix ,& tell them you're looking at buying it & will buy the COA if/when you do buy.
Then get with Dave Walker/toolguy &/or Andy Thonet/SoCal Andy - they're both close in East SD & OC respectively - on what it will cost to resto it .... or at least get it to be a good runner at least!
They've both done their -6 restos recently & should have a good handle on costs & time. Andy is working on some others' -6 restos now too IIRC. PM or email them stat ... pronto .... quick!
At least you won't be upside down with a 6-resto! (IMG:style_emoticons/default/shades.gif)
PS - I knew that "ride" with Andy at Temecula hooked ya! (IMG:style_emoticons/default/happy11.gif)
Also - 80 (or 8010) is Light Ivory - so a bit closer to white than Ivory & there are several 6's around in that color to look at for comparison.
Good Luck! (IMG:style_emoticons/default/beerchug.gif)
Tome
EdwardBlume
post Jun 18 2015, 10:54 PM
Do it already!
pete000
post Jun 18 2015, 11:01 PM
On ebay now...
warpig
post Jun 18 2015, 11:04 PM
http://www.ebay.com/itm/1970-Porsche-Other...utorefresh=true
Sorry, I am the highest bidder (IMG:style_emoticons/default/piratenanner.gif) $202.50 (IMG:style_emoticons/default/bootyshake.gif)
Well that lasted all of about 4 minutes (IMG:style_emoticons/default/dry.gif)
I really don't have room or time for another 914 project car anyway. (IMG:style_emoticons/default/shades.gif)
pete000
post Jun 18 2015, 11:06 PM
Seems like a solid project.
I would just sort it out and drive it !
siverson
post Jun 19 2015, 12:02 AM
Yes, seems like a pretty decent car. It looks somewhat similar in condition to my green car when I got it. And I think the investment required is similar.
I think the math is something like:
$30k - buy the car
$10k - metal/rust/body work
$10k - paint
$5k - interior
$20k - rebuild engine and transmission
$10k - lots of small parts, bolts, rubber, plating, etc
= $85k total + a bazillion hours of work and you have a REALLY nice 914 that you could probably sell for $80k-$85k. But that's at least a year from now, so prices will either be way up, or you'll have $85k into a $40k 914!
But if you're going to do the project to keep it for a long time and have fun, this seems like a really great start.
-Steve
siverson
post Jun 19 2015, 12:08 AM
< Also - 80 (or 8010) is Light Ivory - so a bit closer to white than Ivory & there are several 6's around in that color to look at for comparison.
Are you sure? I understand L80E is Ivory, but sixes had two digit paint codes and "80" should be Silver (80 or 8010),
See:
http://www.p914.com/p914-6_paint_70.htm
and
http://members.rennlist.com/chuxter/914Colors.htm
-Steve
toolguy
post Jun 19 2015, 12:58 AM
From the vin I'm pretty sure that is the car that use to belong to Clark Riener here in San Diego back in the 80's. . he is TPINES on our site. .
The last figures were in the ballpark to restore a 6. . maybe a little light on the rust/body/ paint though depending on what you find when it's apart. . plus, I'd personally want to remove the fiberglass flairs and return it to bone stock. . . that is where the real money is if you want it restored correctly. If it's just to be a driver, do what you want but don't consider it a money making investment in that case.
Same old story, It's usually better to buy the best you can afford rather than doing the restoration yourself. . you seldom get your labor back out of it. .
brant
post Jun 19 2015, 01:01 AM
Kinda depends on the final rust condition. It's not cheap to fix.
ndfrigi
post Jun 19 2015, 01:08 AM
Mike, how about this 6 conversion for $30k.
http://www.914world.com/bbs2/index.php?sho...=258125&hl=
Sedonut
post Jun 19 2015, 01:39 AM
You are making a bet on the 914-6 market. What goes up really fast can go down just as fast.
Personally, having had one, it is not that fast and not that different a car from a 914. You can still buy those all day long in the same condition for $5000 or less.
A sure thing? No.
If you always wanted one, planned on keeping it forever, and like working on them, maybe.
Look at http://forums.pelicanparts.com/porsche-mar...ace-discussion/
post Jun 19 2015, 04:26 AM
914-6 GT in waiting
QUOTE(Sedonut @ Jun 19 2015, 03:39 AM) *
A sure thing? No.
(IMG:style_emoticons/default/agree.gif) don't let people who don't own a six or have never restored a rusty 914 spend your money for you. When you spend $80k to purchase and restore a car that currently has an $80k value, it's not really an investment. Buy it if you always wanted one, don't buy it if the dollars have to make cents
somd914
post Jun 19 2015, 04:36 AM
QUOTE(mepstein @ Jun 19 2015, 06:26 AM) *
A sure thing? No.
If your looking for power, a stock 6 is not the answer - increased displacement 4 has an upper hand there in many ways.
As for the market, as the old saying goes, never buy a car for an investment... There's a lot of money flowing into the classic Euro car market these days. I have to wonder if the bubble will burst soon like the muscle car market did several years back.
However, if you desire to have a 6 and desire a major project, then go for it.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 25th August 2025 - 08:44 AM
