Distributer Question, Need help with a part |
jim_hoyland |
Feb 24 2005, 08:32 AM
Get that VIN ? Group: Members Posts: 9,298 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Just had 914 tuned up and mechanic said I need a new plate inside the distributer, it's getting loose; and because it's a twist in, screws, etc, don't help.Right now, he says I can drive on it a little more...
This 914 is a 1975, manufactured in 7/74 and has the 1.8L FI motor. Can I get a replacement new, used, and where ? Is there a better solution now that I am at this point ? Is there a cleaver work-around ? Any help will be greatly appreciated. Jim |
JoeSharp |
Feb 24 2005, 08:35 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Hi Jim: You know that, that box of parts that I tyred to give you last time you were here, has a dist. in it. Come by and get it.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe |
jim_hoyland |
Feb 24 2005, 08:43 AM
Are there any known upgrades for the distributer that might be compatible with the MSD 6AL. There's a MSD in the car but it was never hooked up; it was too much for my friendly neighborhood non-certified mech; and beyond my s&a
Mueller |
Feb 24 2005, 08:56 AM
are you running points or an electronic ignition? sometimes with a slightly worn distributor, the electronic ignition can help.... you can install a brand new aftermarket distributer, a Mallory unit with points start at about $150, then the next step would be the Mallory Unilite, for about $250 |
jim_hoyland |
Feb 24 2005, 09:08 AM
It's a points type; what is the MAllory part number ?
Mueller |
Feb 24 2005, 10:31 AM
aircooled.net Mallory distributors |
Lo-Fi Version | Time is now: 17th May 2024 - 11:20 AM |
