Front fender replacement |
skier2.0 |
Jun 23 2015, 07:30 PM
Newbie Group: Members Posts: 34 Joined: 30-May 14 From: United States Member No.: 17,422 Region Association: MidAtlantic Region |
Any threads on replacing the front fenders ??
Thanks Rick |
Mike Bellis |
Jun 23 2015, 08:50 PM
Any threads on replacing the front fenders ?? Thanks Rick Just unbolt it and bolt a new one on... Easy as pie. Don't forget the hidden bolt in the glove box! (IMG:style_emoticons/default/hide.gif) |
raw1298 |
Jun 23 2015, 09:21 PM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
The bolts are very tiny.?.? I couldn't find them so I cut them off. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/lol-2.gif)
GeorgeRud |
Jun 23 2015, 09:32 PM
Sure, confuse the newbie! Obviously, they're welded on. Getting the replacement fenders should give you some guidelines as to where to cut and remove the old ones.
Then it's important to properly align them correctly on the chassis. |
rick 918-S |
Jun 24 2015, 06:54 AM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Funny guys... (IMG:style_emoticons/default/smile.gif)
Obviously they are welded on. Question: why are you needing to change a fender? Post some photos of what your wanting to do and I will see if I can help you figure out where to go with it. This may give you an idea about what's involved: http://www.914world.com/bbs2/index.php?sho...=177500&hl= BTW: I may have a used fender. They are very difficult to remove and trim. It requires hours of grinding, seam sealer removal and prep work. |
jsaum |
Jun 26 2015, 03:18 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
After years of asking the same question, looking at post's and Youtube I bit the bullet and took it to a shop to get it fixed here's the before and after. They spliced it in, cost $1500.00 I supplied the fender. I had damage on the corner that I couldn't see how to pull out to get the fender to fit correctly the head light bucket was pushed down about 1/4 of an inch or I would have tried it myself. Post some pictures and see if anyone can point you in the right direction for repairs. Oh and I just picked it up today!
Good luck, Jsaum Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:33 PM |
