phenolic spacers, for intake |
jimkelly |
Jun 23 2015, 10:06 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
seems that intake gaskets already have the phenolic section included??
pic from ebay. Attached image(s) |
DBCooper |
Jun 24 2015, 07:21 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Just to clarify, with dual carbs, IDF's or DRLA's, use the phenolics because they'll keep the fuel in those carbs from heating up and even boiling. But with a center mounted carburetor you really DON'T want to use phenolic spacers. Reason is that with that long run from the carburetor to the head the runners tend to ice up in hot weather and fuel mixture will form droplets. Means it's a good thing to get some heat up into the runners, and no worry because the fuel in a center carb is too far away from the heads to ever get hot enough to boil the fuel in the bowl.
I know that may be a bit counter-intuitive, cool dual carbs, heat a single carb, but that's how it works. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:46 PM |
