Built this combo gauge, Thanks Steve |
gereed75 |
Jun 25 2015, 08:08 AM
Senior Member Group: Members Posts: 1,248 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Just built this combo gauge.
Thanks to Steve Snyder for sending the center button to finish it off. Used an 84 911 combo to get the temp and press modules and a later 914 fuel for the module and face plate. All off ebay for about $150.00. Used condensed gothic dry transfer lettering...fairly close match to the original size and font. A real PITA to put on. Not perfect but looks fine from 2 feet. Made a new back plate per the instructions in various threads on the site. Lots of little dremel cutting (IMG:style_emoticons/default/sawzall-smiley.gif) The generosity and help from the World is really great!! Going out to install. Hope it all works Attached thumbnail(s) |
rhodyguy |
Jun 25 2015, 08:21 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what temp sensor will you be using? for a 4 or 6? the stock sump location if for a 4?
gereed75 |
Jun 25 2015, 08:55 AM
what temp sensor will you be using? for a 4 or 6? the stock sump location if for a 4? For a six. Will use the stock temp sender. Replaced the stock pressure switch with a combo switch and pressure sender for an 84 911. Looks like I will have to add a wire to the harness for the pressure sender. Diagram does not show one but I will check the actual harness since I believe the GT's had a combo gauge in them with pressure. Maybe the wire is actually there. (IMG:style_emoticons/default/confused24.gif) Hope so but doubt it. |
Lo-Fi Version | Time is now: 28th May 2024 - 02:56 AM |
