F/S, various parts |
partwerks |
Jun 28 2015, 02:51 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Various used parts for sale.
Shipping to be added on to the asking price (s) 1. Rear deck lid torsion bars, and brackets. Brackets only, have been sandblasted. $34.00 2. Clutch cable bracket, with nut. $15.00 3. Clutch cable pulley bushing. $3.00 4. Clutch cable clevis, and pin. $10.00 5. Two, fuel pump mounting brackets. Only one bracket has the two rubber isolators, and bolts. $15.00 6. Ball, and cup, throttle linkage. Spring loaded. Size 10 with 32 thread. $15.00 7. Starter that spun over the WRX. $35.00 8. 2004, WRX, 2.0 ECU. Unmarried, $100.00 9. Silicon turbo reducer hose. 3" X 2 3/4" X 3" long. $4.00 10. Aluminum elbow. 1” I.D. 1 1/4” O.D. X 4” X 4 1/2” $3.00 11. Subie, Thermal throttle body gasket. TS-TBG-065 $17.00 12. Fuel pump. In the original ad, it called out to fit these models as well, 911,924,928 1994-77 4,6,8 CYL, but also worked for the Subaru, 2.0, WRX. 12mm X 1.50 pitch Fuel pump had approximately 3 weeks of use on it. Still in good working order when removed. A no name fuel pump. I believe it ran at 38 p.s.i. Changing engine, no longer needed. $40.00 13. Modified terry cable, with threaded bushing, and adjustable mounting bracket. $20.00 14. Oil filter removal tool for WRX, 2.0 $3.00 Any questions, or doubts, just ask. |
Lo-Fi Version | Time is now: 25th May 2024 - 10:09 AM |
