Various used parts for sale.
Shipping to be added on to the asking price (s)
1. Rear deck lid torsion bars, and brackets.
Brackets only, have been sandblasted. $34.00
2. Clutch cable bracket, with nut. $15.00
3. Clutch cable pulley bushing. $3.00
4. Clutch cable clevis, and pin. $10.00
5. Two, fuel pump mounting brackets. Only one bracket has the two rubber isolators, and bolts. $15.00
6. Ball, and cup, throttle linkage. Spring loaded. Size 10 with 32 thread. $15.00
7. Starter that spun over the WRX. $35.00
8. 2004, WRX, 2.0 ECU. Unmarried, $100.00
9. Silicon turbo reducer hose. 3" X 2 3/4" X 3" long. $4.00
10. Aluminum elbow. 1” I.D. 1 1/4” O.D. X 4” X 4 1/2” $3.00
11. Subie, Thermal throttle body gasket. TS-TBG-065 $17.00
12. Fuel pump. In the original ad, it called out to fit these models as well, 911,924,928 1994-77 4,6,8 CYL, but also worked for the Subaru, 2.0, WRX.
12mm X 1.50 pitch
Fuel pump had approximately 3 weeks of use on it. Still in good working order when removed.
A no name fuel pump.
I believe it ran at 38 p.s.i.
Changing engine, no longer needed.
$40.00
13. Modified terry cable, with threaded bushing, and adjustable mounting bracket. $20.00
14. Oil filter removal tool for WRX, 2.0 $3.00
Any questions, or doubts, just ask.
