Speedo set screw leaking? |
last337 |
Jun 29 2015, 07:51 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I am troubleshooting the leak around the speedo cable and after cleaning it, it looks more like the leak is coming from the set screw itself. I havent put a wrench on it or anything yet but it looks like there is a crush washer on the screw itself. Is it possible this is the culprit and not the drive itself. I suspect this because it appears to be wet on the top of the drive shaft itself. I cant seem to find a part # for that crush washer or whatever it is. Also, what is the torque spec on that? I saw reference somewhere to like 9#
McMark |
Jun 29 2015, 09:56 AM
Sometimes this is from the bore getting worn out and allowing the speedo-drive to wobble. The double oring speedo drive an help by stabilizing the drive in the bore.
Lo-Fi Version | Time is now: 17th May 2024 - 04:00 AM |
