last337
Jun 29 2015, 07:51 AM
I am troubleshooting the leak around the speedo cable and after cleaning it, it looks more like the leak is coming from the set screw itself. I havent put a wrench on it or anything yet but it looks like there is a crush washer on the screw itself. Is it possible this is the culprit and not the drive itself. I suspect this because it appears to be wet on the top of the drive shaft itself. I cant seem to find a part # for that crush washer or whatever it is. Also, what is the torque spec on that? I saw reference somewhere to like 9#
Shadowfax
Jun 29 2015, 09:09 AM
Not to say it isn't leaking from the set screw, but the part itself might be the culprit. Check out this link when you get a chance:
http://shop.914rubber.com/Speed-drive-busi...-901318243.htm#
last337
Jun 29 2015, 09:14 AM
I saw that as an option but it looks to be wet above the angle drive itself which is why I suspect the set screw. I cleaned it all off again yesterday and will have to inspect closely after leak continues to be sure.
Shadowfax
Jun 29 2015, 09:18 AM
QUOTE(last337 @ Jun 29 2015, 10:14 AM)
Sounds good. Keep us posted.
McMark
Jun 29 2015, 09:56 AM
Sometimes this is from the bore getting worn out and allowing the speedo-drive to wobble. The double oring speedo drive an help by stabilizing the drive in the bore.
last337
Jun 29 2015, 10:01 AM
Well I have yet to get either plug out and am waiting on my 17mm to come in so hopefully I can at least get those to let go. Will start hitting them with some pb blaster or something soon.
TheCabinetmaker
Jun 29 2015, 10:37 AM
You won't lose much fluid by removing the drive. Not necessary to drain trans
last337
Jun 29 2015, 10:44 AM
QUOTE(The Cabinetmaker @ Jun 29 2015, 11:37 AM)
I am just so hesitant to mess around back there with all the stories of drain/fill plugs getting stuck. Ugh!
TheCabinetmaker
Jun 29 2015, 11:02 AM
Just make sure you can remove the fill plug before you remove the drain plug. Like I said, you won't lose any fluid by removeing the speedo drive.
last337
Jun 29 2015, 11:05 AM
QUOTE(The Cabinetmaker @ Jun 29 2015, 12:02 PM)
Okay thanks! Tracking these leaks down one by one!
Mikey914
Jun 30 2015, 08:06 AM
Got a replacement unit with both o rings and the new shat drive here -
http://shop.914rubber.com/Speed-drive-busi...2-901318243.htm
