Speedo set screw leaking? |
last337 |
Jun 29 2015, 07:51 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I am troubleshooting the leak around the speedo cable and after cleaning it, it looks more like the leak is coming from the set screw itself. I havent put a wrench on it or anything yet but it looks like there is a crush washer on the screw itself. Is it possible this is the culprit and not the drive itself. I suspect this because it appears to be wet on the top of the drive shaft itself. I cant seem to find a part # for that crush washer or whatever it is. Also, what is the torque spec on that? I saw reference somewhere to like 9#
TheCabinetmaker |
Jun 29 2015, 11:02 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Just make sure you can remove the fill plug before you remove the drain plug. Like I said, you won't lose any fluid by removeing the speedo drive.
last337 |
Jun 29 2015, 11:05 AM
Just make sure you can remove the fill plug before you remove the drain plug. Like I said, you won't lose any fluid by removeing the speedo drive. Okay thanks! Tracking these leaks down one by one! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 11:02 PM |
