Shifter Adjustment, Used Racer Chris' method.... |
jim_hoyland |
Jun 29 2015, 04:13 PM
Get that VIN ? Group: Members Posts: 9,306 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Got it the first time.
I had to swap out the Rennshifter for a stock shift temporarily. After the stock unit was in I pulled it over to the passenger door with bungi cord. Then went under the car and turned the shift rod clockwise as far as it could go, inserted a support to keep it from moving while I tightened the pinch bolt. Wow, that was easy ! |
rjames |
Jun 29 2015, 04:36 PM
I'm made of metal Group: Members Posts: 3,936 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Got it the first time. I had to swap out the Rennshifter for a stock shift temporarily. After the stock unit was in I pulled it over to the passenger door with bungi cord. Then went under the car and turned the shift rod clockwise as far as it could go, inserted a support to keep it from moving while I tightened the pinch bolt. Wow, that was easy ! Hmmmm..... thinking about giving this method a try this weekend. My shifter alignment is close to being on, but not as good as I remember it being before attempting to improve the adjustment. (IMG:style_emoticons/default/dry.gif) Right now it's too easy to nick reverse when downshifting into 2nd. Hopefully this well help. Anyone know the torque specks on the pinch bolt? |
jim_hoyland |
Jun 29 2015, 08:44 PM
While I was doing this, I was wondering whether anyone has installed the new Tangerine shift rod adjuster ? Seems like a great idea; even though mine goes into all the gears on the first try, I have the feeling it still needs a micro adjustment in one direction or the other - with the current set up, I,m afraid those tiny adjustments may get away from me. (IMG:style_emoticons/default/smile.gif)
Anyone ? |
bcheney |
Jun 29 2015, 09:16 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
OK I am going to swap out going the opposite direction....moving to a Rennshifter from stock sideshifter set up. How do you adjust the Rennshifter upon install??
jim_hoyland |
Jun 29 2015, 09:32 PM
OK I am going to swap out going the opposite direction....moving to a Rennshifter from stock sideshifter set up. How do you adjust the Rennshifter upon install?? Seems like the same procedure; get the rod turned all the way clockwise; then pull the shifter toward the passenger door and tighten that pinch bolt. I'm going to switch back to the Rennshift after a mod to the base is completed....so if you learn a better way, I'd sure like to know (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:41 PM |
