Door panel cage nut, 5mm or 6mm |
Kansas 914 |
Jun 29 2015, 05:33 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I did some searching and got differing results.
Is the cage nut in the door 5mm or 6mm. Thanks in advance - cheers! |
Mike Bellis |
Jun 29 2015, 06:54 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I did some searching and got differing results. Is the cage nut in the door 5mm or 6mm. Thanks in advance - cheers! What's a cage nut? (IMG:style_emoticons/default/confused24.gif) |
markb |
Jun 29 2015, 07:03 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I did some searching and got differing results. Is the cage nut in the door 5mm or 6mm. Thanks in advance - cheers! What's a cage nut? (IMG:style_emoticons/default/confused24.gif) A nut with a cage around it. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:13 PM |
