Stuck Fuel pressure regulator? |
pete000 |
Jun 30 2015, 04:20 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
74 1.8 L-Jet
Has any one ever had a fuel pressure regulator get stuck from sitting dry? My car has been on jack stands for 4 years. and I finally got all the fuel lines back in. No fuel was going to the fuel rails. I tested the pump and its pumping just fine but no fuel seems to get past the pressure regulator. I took it apart and soaked it in gas and bench tested it with the pump and it seems to be flowing good now. I also checked the cold start valve, fuel rails, and they are not blocked. Have to put it all back in and see. Seems like it just got stuck and would not allow fuel flow. Possible? |
jim_hoyland |
Jun 30 2015, 05:52 PM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My L-Jet has an in-line fuel pressure gauge mounted by the CSV. It really helps in diagnosing l-Jet issues when the motor quits all of a sudden. If engine quits and fuel pressure gage still reads 30 or so, the problem is not fuel related. If it dies and fuel pressure is zero, then it,s most likely a dual relay connection, ground or pump issue.
Lo-Fi Version | Time is now: 19th May 2024 - 07:59 PM |
