Which Sterter Solenoid?, Looking to remedy the infamous hot-start issue |
JDW914 |
Jul 2 2015, 09:37 PM
Newbie Group: Members Posts: 25 Joined: 27-April 11 From: Toledo, Ohio Member No.: 12,990 Region Association: Upper MidWest |
Hi all! I recently took my first long road trip in my 914 (700 mi round trip out to Peoria, IL to finally pick up a replacement windshield) and while the car performed beautifully, I had my first encounter with what I've learned is the "infamous hot-start issue." Happily I was caravanning and, when unable to find a clear reason as to the car's failing to start after a pit stop for lunch, we tried jumping it, assuming the battery had gone bad, which resulted in enough current to pop the solenoid and start it up. This was necessary a few times during the trip. While it has never caused me trouble before (I've been driving the car pretty regularly for 2 years since its restoration has been "finished") I'd prefer to remove the issue so that it doesn't come back to bite me, especially now that the car has proven itself as such a good road-tripper.
Now in my research since encountering the issue, I've found much documentation of the issue and its solutions, in particular a Ford starter solenoid or a Bosch hot start relay kit. I'd like to go about it with the replacement starter solenoid as this seems a simple and straight-forward enough change-out, however, I've not been able to determine what solenoid it is in particular that will fit into an old VW starter motor. Is there a particular part number or set of models/years that use it, or does Ford have enough standardisation that any old solenoid will work? Thanks for any enlightenment you can provide! |
ThePaintedMan |
Jul 4 2015, 07:28 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
I've often heard them used synonymously, so correct me if I'm wrong. But you guys are talking about a Ford solenoid relay, correct? A solenoid is an mechanical lever that is electronically activated (i.e. the trunk "pop" solenoid"). The relay is an electrical component that helps deliver high power to a given component by way of battery power and a low-power signal, correct?
Kansas 914 |
Jul 4 2015, 07:32 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I've often heard them used synonymously, so correct me if I'm wrong. But you guys are talking about a Ford solenoid relay, correct? A solenoid is an mechanical lever that is electronically activated (i.e. the trunk "pop" solenoid"). The relay is an electrical component that helps deliver high power to a given component by way of battery power and a low-power signal, correct? George, You are right. Relay is the more accurate term. Ford relay in line to switch current to the starter solenoid which in turn engages the starter. |
JDW914 |
Jul 4 2015, 09:11 AM
I've often heard them used synonymously, so correct me if I'm wrong. But you guys are talking about a Ford solenoid relay, correct? A solenoid is an mechanical lever that is electronically activated (i.e. the trunk "pop" solenoid"). The relay is an electrical component that helps deliver high power to a given component by way of battery power and a low-power signal, correct? George, You are right. Relay is the more accurate term. Ford relay in line to switch current to the starter solenoid which in turn engages the starter. Well, I had been talking about the mechanical solenoid on the starter, but I was apparently misguided in doing so. It reduces the amount of wire (therefore resistance) in the circuit. Like SLITS said there is no high current running through the keyswitch. The keyswitch simply pulls in the coil of the relay and then the contacts of the relay take the load. I get it now; thanks. Sounds like a relatively simple fix that I ought to be able to manage. |
Lo-Fi Version | Time is now: 28th April 2024 - 10:27 AM |
