Which Sterter Solenoid?, Looking to remedy the infamous hot-start issue |
JDW914 |
Jul 2 2015, 09:37 PM
Newbie Group: Members Posts: 25 Joined: 27-April 11 From: Toledo, Ohio Member No.: 12,990 Region Association: Upper MidWest |
Hi all! I recently took my first long road trip in my 914 (700 mi round trip out to Peoria, IL to finally pick up a replacement windshield) and while the car performed beautifully, I had my first encounter with what I've learned is the "infamous hot-start issue." Happily I was caravanning and, when unable to find a clear reason as to the car's failing to start after a pit stop for lunch, we tried jumping it, assuming the battery had gone bad, which resulted in enough current to pop the solenoid and start it up. This was necessary a few times during the trip. While it has never caused me trouble before (I've been driving the car pretty regularly for 2 years since its restoration has been "finished") I'd prefer to remove the issue so that it doesn't come back to bite me, especially now that the car has proven itself as such a good road-tripper.
Now in my research since encountering the issue, I've found much documentation of the issue and its solutions, in particular a Ford starter solenoid or a Bosch hot start relay kit. I'd like to go about it with the replacement starter solenoid as this seems a simple and straight-forward enough change-out, however, I've not been able to determine what solenoid it is in particular that will fit into an old VW starter motor. Is there a particular part number or set of models/years that use it, or does Ford have enough standardisation that any old solenoid will work? Thanks for any enlightenment you can provide! |
Tom |
Jul 6 2015, 03:07 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
The ford solenoid, ( in this case used as a relay ), is doing exactly the same thing as stated in the link you posted. Perhaps you misunderstood it's use.
Tom |
screenguy914 |
Jul 7 2015, 03:26 AM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
The ford solenoid, ( in this case used as a relay ), is doing exactly the same thing as stated in the link you posted. Perhaps you misunderstood it's use. Tom I think you were directing your response to what I wrote. You're correct in that the Ford remote solenoid does the same thing as a relay. However, it's designed carry starter motor current (e.g. 100+ amps), massive overkill to send a low current (3-5A) control signal to the starter-mounted solenoid. A $4 Bosch relay is all one needs to shorten the source path to the starter solenoid, but up to you. Imagine using multiple Ford solenoids instead of round Bosch relays to energize the vehicle horns, turn signal system, fuel pump etc. It's like using battery cable to replace 14-16 ga. circuit wire in the electrical system. Again, up to you. |
Lo-Fi Version | Time is now: 28th April 2024 - 01:50 AM |
