gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,368 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Can four heater valves fit on a six?? I know that the six valves have the "hole" and I believe that the angle might be slightly different, but are the connection diameters the same and do the actuating levers match up?? (IMG:style_emoticons/default/confused24.gif)
Got my HE's leak tested and looking pretty good and want to re-install them, but thinking of shelving my really good condition six valves if the four ones will work. Thanks |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
In my book, they're the same.
I think the hole in the hat is due to the 911 fan moving more air at a higher pressure. The hole alleviates the possibility of the valve spreader spring being overridden. I have taken the hat off a broken /6 and placed it on a good /4 unit. |
gereed75 |
In my book, they're the same. I think the hole in the hat is due to the 911 fan moving more air at a higher pressure. The hole alleviates the possibility of the valve spreader spring being overridden. I have taken the hat off a broken /6 and placed it on a good /4 unit. Thanks Slits, now to find a reasonable $$ set of four valves |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,048 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
In my book, they're the same. I think the hole in the hat is due to the 911 fan moving more air at a higher pressure. The hole alleviates the possibility of the valve spreader spring being overridden. I have taken the hat off a broken /6 and placed it on a good /4 unit. Thanks Slits, now to find a reasonable $$ set of four valves I should be able to dig up a good pair for you. What do you think is a fair price? Bruce |
Lo-Fi Version | Time is now: 18th July 2025 - 10:47 PM |
