Throttle Cable Routing..Help |
dcecc1968 |
Jul 6 2015, 06:00 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
My throttle cable is binding and needs to be replaced. I have a new cable ready to install, but I noticed the cable comes out of the firewall and up through the rubber seal between the engine and firewall to get topside to my carburetor.....I'm thinking this is probably not correct and was done by the shop I had do some metal work for me last year.
Can anyone point me to a routing diagram (or show me a photo) of the correct cable routing? -Don |
Jul 6 2015, 09:02 AM
The correct cable routing doesn't go to a carburetor at all--it goes to the throttle body on the EFI's intake manifold. Which isn't necessarily in the same location as your carb.
In stock form, the throttle cable goes through a grommet on the right side engine tin, and then over to the throttle body. It may not reach your carb correctly that way, though. In which case you just have to find somewhere that it does fit and work. That's one of the big things with carb swaps to me--there isn't a "correct" way to set it up, because it wasn't done originally by the factory. --DD |
dcecc1968 |
Jul 6 2015, 09:44 AM
Thanks Dave, I understand my current set-up is not original, so let me re-word my request below.
My throttle cable is binding and needs to be replaced. I have a new cable ready to install, but I noticed the cable comes out of the firewall and up through the rubber seal between the engine and firewall to get topside to my carburetors.....I'm thinking this is probably not the best location and was done by the shop I had do some metal work for me last year. Can anyone show me photos of where you've routed the throttle cable to a dual carb set up? |
jsaum |
Jul 6 2015, 09:51 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I have my cable routed the same way as yours for my dual carb set up. It was the only way it would reach. I'm guessing the binding is due to a worn cable as mine doesn't bind.
Jsaum |
dcecc1968 |
Jul 6 2015, 01:12 PM
Lo-Fi Version | Time is now: 17th May 2024 - 02:07 PM |
