Intake Manifold Gaskets, refered to as a phenolic block??? |
Bruce Allert |
Feb 25 2005, 12:04 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
I ordered a set and was told it is a phenolic block. Is this the stuff it's made of or are they giving me sumthin I don't want?
Pelican part# and theirs is # 039 129 707 ...b |
Joe Ricard |
Feb 25 2005, 12:09 PM
Yes the factory intake gaskets are made a Phenolic material. Designed to inhibit heat transfer to the intake runners. I have glued new paper to each side of old block and it worked really good.
For Carbs I have done it both ways. But currently use a thick 1/16" fiberous paper that I cut out and trim to the openings of the ports and bolt studs. My thought here is to keep the carbs warm. |
rhodyguy |
Feb 25 2005, 12:17 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i run them on the carbed car. everything gets plenty warm with them installed. whether they help the heat sinking from the engine i don't know. figure it can't hurt. you want those for your f.i. 2.0 bruce.
k |
TheCabinetmaker |
Feb 25 2005, 12:32 PM
Bruce, Your FI needs them for insulation and spacing Not using them *might* cause the runners to hit the plenum.
(IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) Curt |
Bruce Allert |
Feb 25 2005, 12:36 PM
Well thanks guys. When I first ordered the gaskets they tried to pawn off the 2.0 aftermarket bus gaskets.
NO NO NO NO (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Ya Kev, they're for the FI on the 2.0. I seem to have a vacuum leak (somewhere) (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) but can't find it no matter what I spray in there. I need to take the plennum off & see if there are cracks. I might as well replace the intake tubes & gaskets whilst I'm down that far.... here's hoping. Kev, do you still have that extra 2.0 throttle body that you wanted to get rid of? Is it in ok or good shape. I think mine is some of the cause of leaking air past the brass butterfly. ........b |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:53 PM |
