Fuel Line Quick Disconnect Question, Fuel Line |
Highland |
Jul 7 2015, 08:00 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Just wondering if anyone uses a quick disconnect for the stock D-Jet fuel supply and return line for easier engine removal and install.
If so, what parts and supplier did you use? |
Tbrown4x4 |
Jul 7 2015, 08:14 PM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Geez, how often do you pull your engine?!!
JeffBowlsby |
Jul 7 2015, 09:00 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its just 2 hose clamps, not much could be faster than that.
Highland |
Jul 7 2015, 09:51 PM
I just dropped my engine and had difficulty pulling the hose off the rail, but not the regulator. I had to disconnect the injectors to twist and tug enough to disconnect.
Just looking for an easier way just in case. |
Harpo |
Jul 8 2015, 05:01 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have a set of AN-6 made by jiffy-tite they are an OE supplier to Chrysler. They also have the no leak feature. PM me if your interested. I will try to post a photo later
Lo-Fi Version | Time is now: 17th May 2024 - 05:49 PM |
