Replacement Headlights, Best Bet? |
Grelber |
Jul 9 2015, 11:07 AM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
OK, I'm search challenged........ but what is the best headlight replacement that is plug-n-play, without new wiring or relays?
falcor75 |
Jul 9 2015, 11:16 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Nighthawk LED's from Amazon at about 280$ per side.
Hella H4's with whatever bulb you prefer comes in second place. |
Larmo63 |
Jul 9 2015, 11:43 AM
Hella H4s are good with the biggest wattage bulb you can get away with.
Jul 9 2015, 01:22 PM
johnhora |
Jul 9 2015, 03:20 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
SKL1 |
Jul 9 2015, 04:04 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Just put the GE LED's on both cars- was going to do the H4's with relays but the wiring is a PITA and the LED's, while not cheap, sure are bright!!
Definitely recommend the LED's- just hope they last a long time!! |
rgalla9146 |
Jul 10 2015, 07:44 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
H4s need relays ? with what bulbs ?
rhodyguy |
Jul 10 2015, 08:34 AM
does anyone know if the H2 bulbs work in the H4 lens bodies?
johnhora |
Jul 10 2015, 10:17 AM
You really don't need relays with H4s unless you go crazy with bulbs above the stock 60/55w....something like 100/80w etc....the 8 amp fuse supports about 96w
Make sure all power and ground connectors are clean and shiny the original sealed bulbs were about 40w to 45w |
Geezer914 |
Jul 10 2015, 11:17 AM
Geezer914 Group: Members Posts: 1,417 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Do you need a relay if using H4 100w/55w bulbs? If so, what type of relay are we talking about? Thanks.
john77 |
Jul 10 2015, 11:56 AM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I recently swapped in a pair of the GE NightHawks too. They're expensive, but damn, they are bright.
Having done a little more research, after buying them, [always the best time to do research (IMG:style_emoticons/default/headbang.gif) ] I'm pretty sure Trucklites are the same light. They're somewhat cheaper than the NightHawks and don't have the silver stripe across the centre of the lens. http://www.amazon.com/Truck-Lite-27270C-He...p/dp/B007K8AA7I |
rjames |
Jul 10 2015, 12:05 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
So the LEDs are a direct plug and play?
Grelber |
Jul 10 2015, 12:55 PM
Anybody know about these H4's? They say they are plug n play???
http://www.topgearautosport.com/part/A1010...Conversion.html |
Jul 10 2015, 02:12 PM
Geezer914 |
Jul 11 2015, 10:06 AM
I contacted JWest Engineering about their 911 relay kits, 74-89 and 73 and earlier to see which one would be better for a 914. I converted my 75 914 to H4 headlights using 100w/55w bulbs.
Their response: "Neither, the 911 headlight circuit is very different from the 914. The 914 is actually much more robust. There is really nothing to gain from adding relays unless you are willing to run power from the battery directly to the front trunk, to feed the relays. Which is a lot of trouble and would most likely result in a negligible difference. James, JWest Engineering" Here is a picture of my headlight wires. The ground (brown wire) and the yellow wire appear thicker than the white wire. I have used this set up for 3 years and have not had a problem. It still seems like a good idea to add relays to reduce the load on the switches. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:16 PM |
