I Got DHS, Drooping Headlight Syndrom |
Aaron Cox |
Jun 7 2003, 03:06 PM
(IMG:style_emoticons/default/icon13.gif) doctor? whad do i do?
madd_dogg_914 |
Jun 7 2003, 04:59 PM
Member Group: Members Posts: 478 Joined: 30-March 03 From: Vacaville, CA Member No.: 497 Region Association: Northern California |
Drooping when up, or drooping when down?
Aaron Cox |
Jun 7 2003, 05:46 PM
mostly when down......maybe a little when up
Jeffs9146 |
Jun 7 2003, 06:18 PM
There is an adjustment knob at the top of each headlight motor to bring the sitting position of the headlight up or down.
Jeff Attached image(s) |
rhodyguy |
Jun 8 2003, 09:04 AM
if it's low when raised, check the adjustment stop screw on the back of the bucket assem. it might be too tight.
kevin |
Aaron Cox |
Jun 8 2003, 04:16 PM
i gotta unhook the battery then huh...mine have the tendency to try and fight you if you turn them to much. thanks guys
garyh |
Jun 8 2003, 04:35 PM
Member Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 |
Aaron,
That black knob is NOT an adjustment screw. All that knob does is turn the motor. Take the relay cover off. There are 3 allen screws that hold the pivot. Loosen the screws. Move the headlight into position. Tighten the screws. Gary. |
Aaron Cox |
Jun 8 2003, 04:36 PM
that is what i thought, those are to raise the Headlights if motor is toast....but would this work:
unplug battery, raise headlight to proper position, then plug the battery back up? |
garyh |
Jun 10 2003, 04:16 PM
QUOTE(acox914 @ Jun 8 2003, 02:36 PM) would this work: unplug battery, raise headlight to proper position, then plug the battery back up? NO There's a position sensor on the motor. It will go right back to where it was. Try this experiment: Unplug motor. "adjust position" (with black knob, if you want.) Plug motor back in. After that, and you'll understand. |
Aaron Cox |
Jun 10 2003, 05:30 PM
yep, they go right back to their stupid behavior! so what way do i reposition the pivots?
TIA PS...what is this smiley doing? (IMG:style_emoticons/default/assimilate.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 06:02 AM |
