Shift help |
Shift help |
Bagpype |
Jul 11 2015, 11:00 PM
Newbie Group: Members Posts: 46 Joined: 9-July 15 From: Atlanta, ga Member No.: 18,936 Region Association: None |
Well, as it happens I have more questions. On my tail shift I tried to adjust the shifter obviously wrong. I was jumping out of first so i tried to adjust it. Now it won't even shift into 1st, 3rd, or 5th. It's like there's a block so the shifter won't even go into gear. I know it's an adjustment issue but dr evil's instructions don't work and the 35 year old Haynes manual I have is as useful as a hooker without holes. When I loosen the pinch bolt, I have no way of supporting the shift rod to prevent it moving while the shifter is moved. I am at a complete loss as to what to do. I would like to punch the engineer who designed this shifter in the eye though. Please help. I haven't even been able to drive this car very far. (IMG:style_emoticons/default/headbang.gif)
Bob L. |
Jul 11 2015, 11:44 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Use a pair of visegrip pliers to grab the shift rod through the rear access hole to brace it.
euro911 |
Jul 12 2015, 12:14 AM
... and when you DO finally get it adjusted correctly (fine-tuned), thoroughly clean and mark the rods where they mate with a good permanent method so the whole process will go easier on you the next time you need to disassemble and reassemble it (IMG:style_emoticons/default/shades.gif)
I spent a few hours fine-tuning the linkage on my wife's car after replacing all the shift bushings (also a tail-shifter). It was my first time, didn't mark the rods prior to disassembly, and didn't have the foresight to employ a friend to help when putting it back together (IMG:style_emoticons/default/dry.gif) Patience ... P.S. The engineer who designed it probably isn't alive today (IMG:style_emoticons/default/sad.gif) |
Hank914 |
Jul 12 2015, 02:08 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Well, as it happens I have more questions. On my tail shift I tried to adjust the shifter obviously wrong. I was jumping out of first so i tried to adjust it. Now it won't even shift into 1st, 3rd, or 5th. It's like there's a block so the shifter won't even go into gear. I know it's an adjustment issue but dr evil's instructions don't work and the 35 year old Haynes manual I have is as useful as a hooker without holes. When I loosen the pinch bolt, I have no way of supporting the shift rod to prevent it moving while the shifter is moved. I am at a complete loss as to what to do. I would like to punch the engineer who designed this shifter in the eye though. Please help. I haven't even been able to drive this car very far. (IMG:style_emoticons/default/headbang.gif) Interesting... I had the same problem (could not get first, or it popped out of first right away, but 3rd and 5th were fine), but I did the DrEvil instructions instead of the bungie-cord-to-the-passenger-door thing. I now get first gear 90% of the time, and all other gears 100%. Go figure! |
Bagpype |
Jul 12 2015, 07:46 AM
Well, as it happens I have more questions. On my tail shift I tried to adjust the shifter obviously wrong. I was jumping out of first so i tried to adjust it. Now it won't even shift into 1st, 3rd, or 5th. It's like there's a block so the shifter won't even go into gear. I know it's an adjustment issue but dr evil's instructions don't work and the 35 year old Haynes manual I have is as useful as a hooker without holes. When I loosen the pinch bolt, I have no way of supporting the shift rod to prevent it moving while the shifter is moved. I am at a complete loss as to what to do. I would like to punch the engineer who designed this shifter in the eye though. Please help. I haven't even been able to drive this car very far. (IMG:style_emoticons/default/headbang.gif) Interesting... I had the same problem (could not get first, or it popped out of first right away, but 3rd and 5th were fine), but I did the DrEvil instructions instead of the bungie-cord-to-the-passenger-door thing. I now get first gear 90% of the time, and all other gears 100%. Go figure! The problem is I now don't know which gear its in. I don't know how to manually put it in first. I think its twist the shift tube towards the passenger side, push towards front. To add insult to injury my starter went out during this whole ordeal. At least I know how to fix that! Anyone here from Georgia and feel like showing me what I'm doing? |
Lo-Fi Version | Time is now: 17th May 2024 - 02:41 PM |
