Custom Built Wine Racks, Gauging Interest |
ChrisFoley |
Jul 13 2015, 10:15 AM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I designed this free-standing wine rack for myself using stainless steel tubing.
The first one is 8 bottles high by 14 bottles wide for under counter used. I can easily re-configure for full height by 5 bottles wide. I'll be building this in the next couple of weeks and will post a picture of the completed unit. |
ChrisFoley |
Aug 10 2015, 12:12 PM
Here's the unit nearly completed in my shop:
and loaded with bottles in my living room: The white tubes at the back are hoses for coolant, strung through all the bottle hoops. Here it is in its permanent location in my basement: I'm prepared to custom make these in nearly any size. Contact me for details. |
JmuRiz |
Aug 25 2015, 03:25 PM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Very cool, wish I had the room and collection to justify it.
ChrisFoley |
Aug 26 2015, 02:44 PM
Very cool, wish I had the room and collection to justify it. Its never too late to start a collection, and I can custom build a rack to fit wherever you have room. (IMG:style_emoticons/default/smile.gif) |
ChrisFoley |
Aug 26 2015, 02:51 PM
If you noticed the plastic loops of tubing in the back, those are for the cooling system.
At present I have cold well water trickling through all the bottle support hoops. That is keeping the wine nearly 10 degrees below room temp. I'll upgrade that to a solenoid operated setup with a thermostat for better efficiency. I have an even better cooling system planned, one that is good enough to sell with the rack. It will use a small thermoelectric heat exchanger and a small circulating pump for a closed loop system. The thermoelectric unit will be remotely located so the warm air isn't reintroduced into the storage location. |
kid914 |
Aug 26 2015, 04:58 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
Niiiiiiiiiice work Chris. (IMG:style_emoticons/default/first.gif)
What is the starting price..based on the model from the pics? |
ChrisFoley |
Aug 27 2015, 06:19 AM
Niiiiiiiiiice work Chris. (IMG:style_emoticons/default/first.gif) What is the starting price..based on the model from the pics? Approximately $2600 for the 122 bottle unit shown |
ChrisFoley |
Oct 5 2015, 12:59 PM
I have an even better cooling system planned, one that is good enough to sell with the rack. I'm currently testing the thermoelectric closed loop cooling system. The chilling unit I bought is listed as 50W capacity, but I'm actually drawing closer to 150 watts including the controller, transformer, fan, and circulating pump. First tests were a little disappointing - the lowest temp reached was still above my desired setpoint and the unit was running constantly - but the rack is uninsulated, just protected from air currents. I did install a triple track sliding door with 1/4" birch plywood panels. I found that by reducing the water flow rate my thermal transfer rate improved and the temp dropped some more. I added minimal insulation where it was convenient, but still far from what a fully enclosed unit could be. Now it reaches a lower setpoint (59.5 deg. F) and it holds the bottle temps to about half a degree variation. The next step will be designing the cooling system to be compact and as an integrated part of the product. I'm ready to build a fully enclosed rack next, with double glazed panels and a better prototype chiller attached. |
ChrisFoley |
Dec 18 2015, 11:36 AM
I'm making these countertop racks right now.
They're available at a 15% discount thru Jan 1 2016. Use Coupon Code "holiday15" at checkout. My Webpage (IMG:http://www.914world.com/bbs2/uploads_offsite/www.tangerineracing.com-209-1450460171.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.tangerineracing.com-209-1450460172.2.jpg) |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:13 PM |
