Rear window channel fuzzy strip, Early '72 |
Kansas 914 |
Jul 13 2015, 11:49 AM
I can't find where the early doors used a fuzzy strip in the rear window channel. It just seems wrong when the late doors had one. Am I missing something or does the glass flop around in the rear channel?
I looked at 914Rubber.com and they do show a rear fuzzy but the part number (914.542.171.14) returns 73-76 when I Google it. Mark's part number is 914LFWF so I wonder if that means "Late Door Window Fuzzy"? Trying to get the '72 put back together after 30 years is tough.... EARLY: LATE (showing part 18 as a fuzzy strip): |
hndyhrr |
Jul 13 2015, 11:54 AM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I can't find where the early doors used a fuzzy strip in the rear window channel. It just seems wrong when the late doors had one. Am I missing something or does the glass flop around in the rear channel? I looked at 914Rubber.com and they do show a rear fuzzy but the part number (914.542.171.14) returns 73-76 when I Google it. Mark's part number is 914LFWF so I wonder if that means "Late Door Window Fuzzy"? Trying to get the '72 put back together after 30 years is tough.... EARLY: LATE (showing part 18 as a fuzzy strip): you could send Mark a message he would know, i have a 70 and i just looked and there is no fuzzy in there. that's not to say there should be one and some where along the line it was taken out ....... |
Kansas 914 |
Jul 13 2015, 11:58 AM
cpavlenko |
Jul 13 2015, 12:12 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
My 71 has none.
Kansas 914 |
Jul 13 2015, 12:17 PM
rhodyguy |
Jul 13 2015, 12:26 PM
iirc the plastic piece on the bottom rear of the window rides in the track. the early end cap kind of helps with window wiggle. i think mark sells repros of those.
Kansas 914 |
Jul 13 2015, 12:46 PM
iirc the plastic piece on the bottom rear of the window rides in the track. the early end cap kind of helps with window wiggle. i think mark sells repros of those. Mr. Rhododendron, As I start getting more pieces assembled and out of storage I think you are right about the guide riding in the channel. Early doors/windows are weird.... Now where did I put the windows? |
Kansas 914 |
Jul 13 2015, 01:05 PM
hndyhrr |
Jul 13 2015, 01:39 PM
This is the driver's door showing the rear and center lifts. The front is guided by the metal piece attached to the window glass with tiny rollers. I am getting closer! Yup looks just like mine,except mine is orange. (IMG:style_emoticons/default/biggrin.gif) |
SLITS |
Jul 13 2015, 01:43 PM
While replacing the early doors with late doors and the "good" window lift mechanism is a great idea, it's way to late now. (IMG:style_emoticons/default/sad.gif)
Kansas 914 |
Jul 13 2015, 02:15 PM
While replacing the early doors with late doors and the "good" window lift mechanism is a great idea, it's way to late now. (IMG:style_emoticons/default/sad.gif) Ron, I debated "upgrading" to late doors but trying to keep this one very close to concours, but then I doubt I would lose points for it. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:19 PM |
