Removing Rocker panels, actually how to re-install |
jr91472 |
Feb 26 2005, 12:00 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
My rockers are looking pretty tired. So I am planning to remove, strip, and re-paint.
They are currently on with rivets which I assume I can simply drill out. Correct? But how to I re-install? Never done any riveting. Is it hard? Can you buy a cheap revit gun? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Or, is there a better alternative. I am a little lost here, so any suggestions / directions would be appreciated. thx (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
Aaron Cox |
Feb 26 2005, 12:01 PM
Haynes: Installation is the reverse of removal procedure (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Allan |
Feb 26 2005, 12:04 PM
Funny guy Aaron. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Just drill out the rivets and remove the screws along the bottom and the ones at each wheel well. I'm going to use stainless shallow pan head screws to hold the top of mine on so they will be easily removed for routine cleaning. |
GaroldShaffer |
Feb 26 2005, 12:10 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I just removed mine also. Rocker panels To reinstall just get a hand held rivet gun, rivets and re-attach. When you remove them there are three screws on the bottom side plus there should be one inside each fender. Don't do like I did and loose the rubber instolator thingy that goes at each end by the fender. I lost two (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
boxstr |
Feb 26 2005, 12:13 PM
I have removed and installed a bunch of these. Got to the hardware stoes and get yourself a pop rivet gun, @$15-20.00 for a good one. Then get yourself a box of rivets. Take the rocker panel with you if you are unsure of the size. Then just pop rivet the rocker back on. It looks much better, and it has a clean stock appearance.
One thing is to get stainless steel bolts and washers for the three holes on the bottom of the rockers. Also add some antiseize before screwing them back in. The two wheelwell bolts can also be changed out for, speed nuts on the rocker panel and then a stainless screw to hold it on, also try and replace the rubber spacers between the body and the rocker panels. It helps to have a really well stocked hardware store close by. One more thought, paint the back side of the rrockers and valances, keeps the corrosion at a minimum. I am installing the rockers and valances on the black 6 today. Good luck. CCLINROCKANDROLL |
Cap'n Krusty |
Feb 26 2005, 12:16 PM
You can buy black anodized rivets to match the originals, BTW. The Cap'n
jr91472 |
Feb 26 2005, 02:49 PM
wilchek |
Feb 26 2005, 04:32 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
I just put my rockers back on today. I was going to use screws, but to keep it looking original, I put the rivits back in. Took five minutes to do. Use 1/8 (1/8x1/4 to be exact) rivets with any rivet gun. Just put the rivert in the hole with the long end of the nail pointing up. Put the nail point in the rivet gun hole and squeeze the handle a couple of times. On the second or third squeeze the nail part will break off and the rivet will be flush. It is a lot easire than it sounds. GOOD LUCK
EDIT: Oh yeah, The bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4. I used a hex head for both, as I think they are less prone to strip out. The bottom three bolts are tight with the hex head, but fit. I was unable to find stainless 6MM bolts so I ended up with zinc and stainless washers. GOOD LUCK RIVET GUN: http://www.sears.com/sr/javasr/product.do?...pid=00974731000 RIVETS: http://www.sears.com/sr/javasr/product.do?...pid=00974618000 |
kenpolives |
Feb 26 2005, 05:59 PM
Member Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
I decided to replace my rockers with ABS rockers (with the porsche lettering), we I got them from AA (mistake) they came this week, fiberglass not plastic, and no holes predrilled. Worse - gray finish - no I have to get them painted and hope I don't f&*(& them up when I drill the holes.
jr91472 |
Feb 26 2005, 06:02 PM
sweeet...thanks a bunch (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Orange914x2 |
Feb 26 2005, 08:27 PM
Newbie Group: Members Posts: 18 Joined: 3-December 04 From: San Diego CA. Member No.: 3,213 |
I have had to take my rockers off 5 or 6 times per side and I’ve found that the bigger aluminum rivets actually look pretty cool when contrasted with the black (especially if you have aluminum thresholds) they’re also real easy to drill out. the only tricky part is inserting the rivet without chipping the paint underneath (it's a great little spot for water to pool up and start rust around the rivets). So I solved this by cutting some RC car fuel line into little washers that fit onto the rivet. This allows the rivet to break properly without chipping your paint in the process. it actually compresses the rubber fuel line to the point where it becomes a gasket that seals the hole and looks like a clear rubber washer.
can post picts later. |
Porsche Rescue |
Feb 27 2005, 12:40 AM
A CW question here, but aren't the original rivets for the rockers the same plastic ones used on the threshold plates? I know that most are now pop rivets or screws but what is factory correct? My recall is white plastic for the early cars and black plastic for later cars. CW's, help me out.
Lo-Fi Version | Time is now: 5th May 2024 - 03:23 AM |
