Late engine bar question |
sixaddict |
Jul 18 2015, 12:03 PM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Which side does hole in mount bar go...sorry for dumb question dujour but not a 4 guy
JawjaPorsche |
Jul 18 2015, 12:08 PM
Which side does hole in mount bar go...sorry for dumb question dujour but not a 4 guy Driver's side. If I understand your question. Shift bar goes through it. Attached image(s) |
sixaddict |
Jul 18 2015, 12:36 PM
rhodyguy |
Jul 18 2015, 01:21 PM
If your engine is out put the the rear rod thru the hole before you install the engine. Engine still in? put the rod in the bar before you bolt it up the bar.
bdstone914 |
Jul 18 2015, 09:55 PM
If your engine is out put the the rear rod thru the hole before you install the engine. Engine still in? put the rod in the bar before you bolt it up the bar. That really is not needed. It would just get in the way and is easy to install after the engine is in. Just had to help a friend who put in the engine bar the wrong way and could not get fourth and Fifth. The shift rod will bind on the engine bar and prevent it from fully rotating. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:53 PM |
