911 swivel feet adjusters...., Need the low down.... |
Aaron Cox |
Feb 26 2005, 10:12 PM
my rockers are in ugly shape... need to be replaced.
im looking at a set of 1.7 rockers (8mm) and wanting to go 911 swivel feet.... gimme the low down.... *need to have the faces cut back .060 *what adjusters to run? (OEM 911???) * aircooled.net has a few different setups and anyone have a set of 1.7 rockers???? |
Bleyseng |
Feb 26 2005, 10:28 PM
yep,
cut .60 of the face oem 911 ones only I might have a extra set ... Geoff |
Mark Henry |
Feb 27 2005, 07:06 AM
You will also need shims, longer HD 8mm rocker studs and most likely Cr-Mo pushrods.
Buy, borrow or make an adjustable pushrod for the proper (important) geometry set up...you'll find your stock pushrods will be the wrong length when your done. |
MXMARK |
Feb 27 2005, 09:15 AM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
Aaron, I have the 911 setup in my motor with push rods cut to make geometry correct. Thanks Mark
Lo-Fi Version | Time is now: 5th May 2024 - 05:57 AM |
