Aaron Cox
Feb 26 2005, 10:12 PM
my rockers are in ugly shape... need to be replaced.
im looking at a set of 1.7 rockers (8mm) and wanting to go 911 swivel feet....
gimme the low down....
*need to have the faces cut back .060
*what adjusters to run? (OEM 911???)
* aircooled.net has a few different setups
and anyone have a set of 1.7 rockers????
Bleyseng
Feb 26 2005, 10:28 PM
yep,
cut .60 of the face
oem 911 ones only
I might have a extra set ...
Geoff
Mark Henry
Feb 27 2005, 07:06 AM
You will also need shims, longer HD 8mm rocker studs and most likely Cr-Mo pushrods.
Buy, borrow or make an adjustable pushrod for the proper (important) geometry set up...you'll find your stock pushrods will be the wrong length when your done.
MXMARK
Feb 27 2005, 09:15 AM
Aaron, I have the 911 setup in my motor with push rods cut to make geometry correct. Thanks Mark
