928 engine in 914 |
928 engine in 914 |
EdwardBlume |
Jul 24 2015, 07:40 AM
Webers on a 928 engine have been done. There was a street rod done in California in the 80's. More of a show car than a driver. 928 engines are a very different animal. The US spec engines are only 218-219 hp. Kind of a waste of time when you can bolt in a 6 with no drama and get that easy. The euro engines stock are 300-310 advertised hp. (IMG:style_emoticons/default/shades.gif) The engines are higher compression, have larger valves, bigger ports, the inside of the spyder runners are larger and the throttle body is way bigger than the US engine. There are very few mods that can be done. The challenge is the block. It's made of allusil. The whole block. You can only run the special iron coated pistons. Try to use aftermarket pistons and they stick to the block. (IMG:style_emoticons/default/unsure.gif) The other limitation are the cams. They are a long duration short lift designed for F.I. Not suited for carbs. The engine I have is what is called a hybrid. I am running a 5.0 block and pistons. The 5.0 is a 32 valve engine. I had the piston notched for 16 valve heads. I have a complete euro-spec "S" 16 valve top end with CIS. This combo is producing over 350 RW hp. in the 928's turning all the accessories. I'm only turning an alternator. (IMG:style_emoticons/default/assimilate.gif) Oh: and I used a 901 with an HB 5th and sorted stack. It's a custom length side shift. (as in I cut the housing with a router to make it fit. No one makes any conversion parts. I made my own adaptor plate and custom flywheel and clutch. I drive the car hard. Sandy and I have been to almost every corner of the country more than once. I built a cruiser not a town car. Rick, It would be great to see your built alien in person one day. Don't know if you went to the last WCR. Dave Good news - there are 2 things that make Rick come to CA - a good deal and a good time. |
Elliot Cannon |
Jul 24 2015, 12:44 PM
thanks for all the input. and by the was taking advice from a guy that doesn't eat meat is like taking advice from a woman, rite Elliot The only advice I give people is, if you eat meat it will kill you. Eventually. (IMG:style_emoticons/default/av-943.gif) |
montoya 73 2.0 |
Jul 24 2015, 01:06 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Rumor has it (IMG:style_emoticons/default/hide.gif) that Rick may be moving to the West coast because Mark is moving East! (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/biggrin.gif)
rick 918-S |
Jul 24 2015, 06:02 PM
Hey nice rack! -Celette Group: Members Posts: 20,477 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Webers on a 928 engine have been done. There was a street rod done in California in the 80's. More of a show car than a driver. 928 engines are a very different animal. The US spec engines are only 218-219 hp. Kind of a waste of time when you can bolt in a 6 with no drama and get that easy. The euro engines stock are 300-310 advertised hp. (IMG:style_emoticons/default/shades.gif) The engines are higher compression, have larger valves, bigger ports, the inside of the spyder runners are larger and the throttle body is way bigger than the US engine. There are very few mods that can be done. The challenge is the block. It's made of allusil. The whole block. You can only run the special iron coated pistons. Try to use aftermarket pistons and they stick to the block. (IMG:style_emoticons/default/unsure.gif) The other limitation are the cams. They are a long duration short lift designed for F.I. Not suited for carbs. The engine I have is what is called a hybrid. I am running a 5.0 block and pistons. The 5.0 is a 32 valve engine. I had the piston notched for 16 valve heads. I have a complete euro-spec "S" 16 valve top end with CIS. This combo is producing over 350 RW hp. in the 928's turning all the accessories. I'm only turning an alternator. (IMG:style_emoticons/default/assimilate.gif) Oh: and I used a 901 with an HB 5th and sorted stack. It's a custom length side shift. (as in I cut the housing with a router to make it fit. No one makes any conversion parts. I made my own adaptor plate and custom flywheel and clutch. I drive the car hard. Sandy and I have been to almost every corner of the country more than once. I built a cruiser not a town car. Rick, It would be great to see your built alien in person one day. Don't know if you went to the last WCR. Dave Good news - there are 2 things that make Rick come to CA - a good deal and a good time. You know me so wellRob! (IMG:style_emoticons/default/smile.gif) Yes Dave, Sandy and I were there. We have been to several Western events with the Alien. But this year we were in 7 of 9. She has since been assimilated (IMG:style_emoticons/default/assimilate.gif) into a new family that really digs her. (IMG:style_emoticons/default/wub.gif) Photo from the new owner. I changed the color of the hood before she left but I didn't touch her big tits. |
rick 918-S |
Jul 24 2015, 06:07 PM
thanks for all the input. and by the was taking advice from a guy that doesn't eat meat is like taking advice from a woman, rite Elliot The only advice I give people is, if you eat meat it will kill you. Eventually. (IMG:style_emoticons/default/av-943.gif) Oh I don't know about that Elliott... That sandwich you had at the picnic luncheon damn near caused you to break your neck or something... |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:29 AM |
