karmen plate and trunk numbers |
wilchek |
Feb 27 2005, 01:43 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
I have two pictures attached of the karmen plate in the door jamb and the trunk number stamping. Should these numbers match? The numbers are two off. My car has been Ravene Green for some time and the door vin sticker has Ravenna Green under it. However the dash plate is the orange that goes with the Door plate stamp of "L 20 E". Is it possible that the factory messed up and realized it and never changed the door plate. The rest of the car is Ravenna and does not have any orange under anypart of the green that I can find. The floor pans, the firewalls all the rest of the car is green and had to be painted apart. Any ideas?? Should the trunk number match the plate. Two numbers off is strange. The car is local owed and I am the third owner. The guy who I bough it from was the salesman who sold the car to the original owner. He was unsure, but always remembered the car as green.
(the picture looks different colors due too the flash) Attached image(s) |
Feb 27 2005, 02:10 PM
Resident German Group: Admin Posts: 41,622 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the dash underframe almost always has a different color (sometimes none, primer only) ... they were put in after the car was painted and simply came off a big pile of parts. there's no reason to worry about the mis-match there ... as for the paint-code on your karmann plate, it could be that the original plate was lost and it was replaced with this one later. was the car ever repainted (in original color)? if so, they probably removed the original plate and lost it and put this one on there later ... how hard did you look for a color-change? any overspray on any parts (wire-harness etc.) ? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Bleyseng |
The guy at karmann probably screwed up as it was Friday. Now your car is worth a ton of money!!
Have a COA done on it by Porsche to see what the color in listed on their build sheet. Geoff (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
wilchek |
Feb 27 2005, 03:10 PM
I have looked everywhere for overspray. I just don't see it. The hood bolts are not paints also which leads me to believe that it was original. How often does someone pull the hood to paint a car. Under the vin sticker is green. Who would spend the time to get a new vin sticker. Also the HO recal campaing sticker is still next to the VIN. It seems kind of unusual for the car to have been repainted prior to the the early 80's when the HO was done.
how do I get a COA done? |
wilchek |
Feb 27 2005, 03:21 PM
PICS
wilchek |
Feb 27 2005, 03:23 PM
It seems odd that they would find a plate that is TWO serial number off |
Gustl |
Feb 27 2005, 03:37 PM
914 enthusiast & historian Group: Members Posts: 11,495 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
I'm pretty sure that there is an other car around, with a Karmann plate that says 5049559 and L65K and the stamped in Karmann number 5049601 in the trunk.
This teener is orange, off course (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Gustl |
Lo-Fi Version | Time is now: 5th May 2024 - 01:08 PM |
