914-6 oil level |
914-6 oil level |
Peashooter |
Jul 28 2015, 09:32 AM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
The owner's manual for my 914-6 calls for 9.5 qts. of oil. After installing my engine for the first time, keeping in mind it was completely apart, clean tank, lines, etc, it didn't show on the dipstick(warm and at idle) until 10 qts were in, and it still shows low.
Any thoughts on this? I am thinking the 9.5 refers to an oil change, there being some residual oil left in the lines,etc. Thx, Bill |
siverson |
Jul 28 2015, 10:24 AM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Yup, that sounds about right.
-Steve |
Perry Kiehl Clone |
Jul 28 2015, 12:33 PM
Unregistered |
You are checking it with the engine warm and idling on level ground? An extra 1/2 quart isn't going to cause a problem.
rgalla9146 |
Jul 28 2015, 01:22 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
No enthusiast owned 911 or 914 6 should show oil above the half full mark.
914itis |
Jul 28 2015, 02:32 PM
Oil changed , drained both from tank line and motor , took 11 1/2 quarts.
larryM |
Jul 28 2015, 10:11 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
X2
also be aware that there are some incorrect dipsticks in the wild i b'ot one yrs ago, "certified" oem -6 from a guy who sold us all a lot of -6 stuff - it was nowhere near my real oem stick in length or marks original -6 German lid sticker says "5 min, 7 max" - see picture my car with front Behr GT cooler likes 10 qts - if more, it blows it out the vent (and into the track required "catch can") Yup, that sounds about right. -Steve Attached image(s) |
6freak |
Jul 29 2015, 07:48 AM
The owner's manual for my 914-6 calls for 9.5 qts. of oil. After installing my engine for the first time, keeping in mind it was completely apart, clean tank, lines, etc, it didn't show on the dipstick(warm and at idle) until 10 qts were in, and it still shows low. Any thoughts on this? I am thinking the 9.5 refers to an oil change, there being some residual oil left in the lines,etc. Thx, Bill the book tells you 9.5 then put 9.5 in ! Steve is right and mines the same it reads just a bit low,but check it when the car is hot and has been driven 11.5 is to much in a stock system MikeC |
Peashooter |
Jul 29 2015, 06:12 PM
Thanks for the replies...since my car was all apart when I got it, I am not 100% sure the oil fill neck and dipstick are right. I have a friend with an original six and I am going to stop by and compare the two. If everything looks good, then I will fill it to where it is reading correctly, then see what it takes when I do a simple oil change. That should be the 9.5 qts. I hope!
patssle |
Jul 29 2015, 07:36 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I think I put in about 11 quarts the first time after my /6 conversion. It was bone dry and no external oil cooler.
Lo-Fi Version | Time is now: 15th May 2024 - 01:04 PM |
