Pushrod Tube seals, viton seals |
Alphaogre |
Jul 28 2015, 11:51 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Has anyone used these viton seals before on the pushrod tubes and valve covers? I would be curious if they would help with the leaking or not?
http://www.autoatlanta.com/Porsche-914-Vit...l-Kit-srch.html Pushrod Tube Seal Kit Who wants to constantly perform the dirty, greasy pushrod tube replacement procedure when these space age viton seals eliminate the problem for years! rated at 450. Degrees, if installed properly you should never have to replace the seals again! Kit comes complete with precise instructions and valve cover gaskets. Everything you need except hand cleaner! Consists of: 8 b021 109 345 a; 2 r021 101 481; 1 rtc 1022 make sure that you readjust the valves and check the valve adjuster lugs for damage. Kit consists of: 8 - b021109349b - pushrod tube seal, large - normally $20.00 8 - b021109345a - pushrod tube seal viton - normally $8.00 2 - r021101481 - valve cover gasket - normally $2.40 1 - btc1022...(choose a part on the right to read more) |
ThePaintedMan |
Jul 28 2015, 02:31 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Dave nailed it. You indeed do not have to pull them all the way out, but contrary to what some believe, they can be pulled completely out if you pull the pushrods out first on the couple that run into the console.
Before attempting to change them, take GOOD notes on how the long, snake-like pushrod retainer wire is routed. I got it wrong and it ate into a pushrod (aluminum). Double and triple check that you have it routed correctly when you reinstall by using a mirror and/or cell phone camera. You also want to clean out all oil and debris from the pushrod tube bores before you pull them so you don't get any inside the case. |
Lo-Fi Version | Time is now: 19th May 2024 - 11:21 AM |
