Pushrod Tube seals, viton seals |
Alphaogre |
Jul 28 2015, 11:51 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Has anyone used these viton seals before on the pushrod tubes and valve covers? I would be curious if they would help with the leaking or not?
http://www.autoatlanta.com/Porsche-914-Vit...l-Kit-srch.html Pushrod Tube Seal Kit Who wants to constantly perform the dirty, greasy pushrod tube replacement procedure when these space age viton seals eliminate the problem for years! rated at 450. Degrees, if installed properly you should never have to replace the seals again! Kit comes complete with precise instructions and valve cover gaskets. Everything you need except hand cleaner! Consists of: 8 b021 109 345 a; 2 r021 101 481; 1 rtc 1022 make sure that you readjust the valves and check the valve adjuster lugs for damage. Kit consists of: 8 - b021109349b - pushrod tube seal, large - normally $20.00 8 - b021109345a - pushrod tube seal viton - normally $8.00 2 - r021101481 - valve cover gasket - normally $2.40 1 - btc1022...(choose a part on the right to read more) |
Alphaogre |
Jul 28 2015, 05:09 PM
The short version of the instructions: Pull the tubes halfway out of the head to replace the seals. No need to pull them out to the point where they run into the suspension console. --DD WHAT !?!?! you don't have to pull the full motor and everything down to the pistons to replace these?!?! DAMN IT! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/biggrin.gif) Thanks for the info, I have the whole thing pulled apart anyway, so I figure now would be a good time to change everything. Are the cork ones more prone to leaking then the viton seals for the valve covers? (my cork ones have leaked in the past. I think they just get saturated. I saw this article that was pretty interesting. Anyone add the lips to the valve covers? http://www.pelicanparts.com/techarticles/9...alve_covers.htm |
Lo-Fi Version | Time is now: 19th May 2024 - 03:42 PM |
