Pushrod Tube seals, viton seals |
Alphaogre |
Jul 28 2015, 11:51 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Has anyone used these viton seals before on the pushrod tubes and valve covers? I would be curious if they would help with the leaking or not?
http://www.autoatlanta.com/Porsche-914-Vit...l-Kit-srch.html Pushrod Tube Seal Kit Who wants to constantly perform the dirty, greasy pushrod tube replacement procedure when these space age viton seals eliminate the problem for years! rated at 450. Degrees, if installed properly you should never have to replace the seals again! Kit comes complete with precise instructions and valve cover gaskets. Everything you need except hand cleaner! Consists of: 8 b021 109 345 a; 2 r021 101 481; 1 rtc 1022 make sure that you readjust the valves and check the valve adjuster lugs for damage. Kit consists of: 8 - b021109349b - pushrod tube seal, large - normally $20.00 8 - b021109345a - pushrod tube seal viton - normally $8.00 2 - r021101481 - valve cover gasket - normally $2.40 1 - btc1022...(choose a part on the right to read more) |
Elliot Cannon |
Jul 29 2015, 10:49 AM
Used by FAT Performance, European Motor Works and the California Central Coast School of High Tech Stuff. But (IMG:style_emoticons/default/WTF.gif) do they know? (IMG:style_emoticons/default/av-943.gif)
Attached image(s) |
Alphaogre |
Jul 29 2015, 12:05 PM
Used by FAT Performance, European Motor Works and the California Central Coast School of High Tech Stuff. But (IMG:style_emoticons/default/WTF.gif) do they know? (IMG:style_emoticons/default/av-943.gif) Thats interesting, is that the Locktite pipe sealant in the photo? |
914_teener |
Jul 29 2015, 06:46 PM
914 Guru Group: Members Posts: 5,200 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
e='Jul 29 2015, 11:05 AM' post='2216313']
[quote name='Elliot Cannon' post='2216285' date='Jul 29 2015, 09:49 AM'] Used by FAT Performance, European Motor Works and the California Central Coast School of High Tech Stuff. But (IMG:style_emoticons/default/WTF.gif) do they know? (IMG:style_emoticons/default/av-943.gif) [/quote] Thats interesting, is that the Locktite pipe sealant in the photo? [/quote] Ignore that photo ........... It is infamous here and will lead you down the yellow brick road to be attacked by flying monkies (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/stirthepot.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 09:47 AM |
