Pushrod Tube seals, viton seals |
Alphaogre |
Jul 28 2015, 11:51 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Has anyone used these viton seals before on the pushrod tubes and valve covers? I would be curious if they would help with the leaking or not?
http://www.autoatlanta.com/Porsche-914-Vit...l-Kit-srch.html Pushrod Tube Seal Kit Who wants to constantly perform the dirty, greasy pushrod tube replacement procedure when these space age viton seals eliminate the problem for years! rated at 450. Degrees, if installed properly you should never have to replace the seals again! Kit comes complete with precise instructions and valve cover gaskets. Everything you need except hand cleaner! Consists of: 8 b021 109 345 a; 2 r021 101 481; 1 rtc 1022 make sure that you readjust the valves and check the valve adjuster lugs for damage. Kit consists of: 8 - b021109349b - pushrod tube seal, large - normally $20.00 8 - b021109345a - pushrod tube seal viton - normally $8.00 2 - r021101481 - valve cover gasket - normally $2.40 1 - btc1022...(choose a part on the right to read more) |
Mikey914 |
Jul 29 2015, 10:57 AM
The rubber man Group: Members Posts: 12,672 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Cork or silicone. I make both. Personally I like the cork best. I have made both versions 1/16" thicker than OEM and slightly wider to seat better than the others on the market.
Selling point on the silicone is they are reusable. Just my .02 |
Dave_Darling |
Jul 29 2015, 05:47 PM
rjames |
Jan 22 2021, 05:30 PM
I'm made of metal Group: Members Posts: 3,940 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I've reused the cork valve cover gaskets at least a half-dozen times. The only time it has ever leaked was when I shifted the gasket out of position messing with the cover retaining bale. --DD (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 07:01 AM |
